STS Twin Turbo Kit?
Old Mar 7, 2005 | 09:54 AM
FLeXNuTZ's Avatar
Default STS Twin Turbo Kit?
I like the idea of the rear mount turbo on the STS kits but what about a twin turbo kit like this? Would it work? The reason I ask is because the turbo is mounted on the left side on the current kit. I dont' know very much about the STS kits but it would be cool if this could be done. Please give me your thoughts on this.
T.J.
Old Mar 7, 2005 | 10:14 AM
SS00Blue's Avatar
Search for "Jammer" He's blazing that trail.
SC-
Old Mar 7, 2005 | 10:52 AM
FLeXNuTZ's Avatar
Thanks, I didn't know anyone else had posted about this.
Old Mar 7, 2005 | 10:58 AM
HAMRHEAD's Avatar
I think that would nice to see as well!
Old Mar 7, 2005 | 11:21 AM
Boostaholic's Avatar
I don't think there is a real big advantage going twin turbos, its kind of a bling factor thing. So doing rear mount twins kind of makes it pointless.
Sure you can get smaller twins to spool a little faster and harder, but loose top end, or even spool normally and have great top end, but I just don't see the point of rear mount twins unless you just like spending money.
Old Mar 7, 2005 | 04:08 PM
FLeXNuTZ's Avatar
Oh okay. I was always under the impression that twins made more power, hence my question in this thread. If I can get just as much out of a big single turbo then I'm all for it. I don't care about bling so much, I just want my passengers to **** themselves when they feel the raw power of a turbo'd LS1.
Old Mar 7, 2005 | 04:58 PM
Then a correctly sized single turbo should do the job for you.
Old Mar 7, 2005 | 05:46 PM
HellRaiser's Avatar
Yeah JAMMER is makeing a twin kit now. He's prolly close to finished and from the pics it looks very clean. Should be a fun setup. But I think its more for the bling fator to.
Old Mar 7, 2005 | 06:02 PM
BiggerJ's Avatar
It might be benificial if you were to do a bi-turbo/serial turbo type thing. Where turbo 1 was small and spooled super quick and then as exhaust back pressure built up turbo 2 would spool and take over. The transition from 1 to 2 would be a little tricky but doable. That way you get the best of both worlds, almost instantaneous boost and high rpm boost.
Old Mar 7, 2005 | 06:13 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Flipper has built a twin kit for his crew cab... It's an awesome truck. worth pressing search I promise.
Old Mar 7, 2005 | 06:16 PM
Silver02Z28's Avatar
That's an idea, sequential rear mounts. That might cure the slow spool and/or running out of steam problem with correct turbo sizing. What turbo could I plug into my H2D to pick up the low end?
