Home built turbo kit ???'s
Has anyone done an STS or similar kit by a home build? Doing it all yourself and buying an aftermarket t3 or t4 or something bigger? Any input? Ideas? Cost aspects? Previous project pictures maybe!~?
Any input would help, I would like to start next month.
Thanks in advance guys!!!
-Garrett
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
-Garrett
14 Second Truck Club
A guy in the truck section named Flipper also did a twin rear mount. There was also a web site for a guy that did a rear mount with a junk yard turbo on a cavalier, it was kinda quick for the miles and cost.
Building your own kit is cheaper, but its gets expensive quick. Here's a list another member made.
Part Part# Source Cost
MP62-1 turbo .68 AR, 3” hot outlet, T4 hot inlet, 4” cool inlet, 2.5” cool outlet MP62-1 TPS, http://boostedsystems.com/ 600
Wastegate, Tial 38mm TPS 200
Blow off valve, turbo XS RBV H34 Ebay, used average 71
Blow off valve adapter, 3” hose to 34mm Turbosmart 911-ADAHT300 Jegs 50
Electronic boost controller & turbo timer GReddy PRofec-B2 Ebay, several vendors, shipped 335
Inlet pipe to turbo TPS custom TPS w/ flanges T4/38mm 60
3” V-band clamp & adapter to turbo TPS 35
3” exhaust pipe- turbine outlet to muffler- 90 degree bend 502-12007 Jegs 32
Supertrapp 3” in 5” out 549-3019 http://carshopinc.com/ shipped 140
2.5 to 2.25 transition- compressor outlet http://shop.store.yahoo.com/titanmotorsports/ 23
(2) 2.25” compressor outlet pipe- J-bend- make 90 degree pipes as needed (cheaper) 289-42428 Jegs
50
2.25” pipe to front of car 8’ length T304 SS 7955952841 Ebay- Vertex Now 92
(1) 2.25”-3” silicone adapter at intercooler (in/out) http://shop.store.yahoo.com/titanmotorsports/ 23
3.0”-3.5” adapter to MAF Ebay, jstonestang 18
Inlet elbow- 90 degrees 3” LT1 Vortech w/ hoses 933-4GH112-050 Jegs 75
2.25” silicone straight couplers w/ clamps ( comes as 4) Ebay, jstonestang 48
2.25” t-bolt clamps (2) Ebay, Partssystemscom (2 @2.65 ea) 5
2.5” t-bolt clamp, turbo outlet Ebay, Partssystemscom 3
3” t-bolt clamps (2) Ebay, Partssystemscom (2 @2.74 ea) 6
3” silicone couplers w/ clamps (12- order set of 4 x 3) Ebay, jstonestang 120
4” silicone connetor, pipe to turbo inlet (T-bolt clamps listed w/ elbow below) http://shop.store.yahoo.com/titanmotorsports/ 8
Air filter 4” inlet 599-RF-1015 Jegs 40
Air filter cover 599-RF-1015DK Jegs 30
Inlet pipe to turbo 4” x 4’, cut to fit, use elbow 555-30613
Jegs 18
4” silicone elbow & T-bolt clamps (5) Ebay, hightempsilicone 65
Oil subsystem (see below) See below 464
Vac/pressure line, engine to EBC and EBC to wastegate, 2 x 10’= 20’ 969-5780 Jegs 34
Pipe hanger- universal 4” intake to car, uses muffler clamp Advance Auto Parts 6
Pipe hanger- universal 3” muffler to car, uses muffler clamp Advance auto Parts 6
Additional small parts, fasteners, misc. 50
Additional shipping costs except Jegs (see below) 60
Total 2767
Specific parts to build oiling system:
Part Part # Source Cost
Supply side:
Adapter to block 1/4 MPT nipple 023-FCM2133 Jegs 5
1/4 NPT T-fitting: 1- block adapter, 2- pressure switch 3-supply hose 799-661720 Jegs 12
Pressure switch for pump OPS47 Advance Auto Parts 6
Adapter, 1/8 FPT to 1/4 MPT 369-991201 Jegs 3
Adapter, ¼ MPT to –6 AN male 555-100104 Jegs 3
-6 AN hose assembly, 90 degree swivel x straight, used, 40” IC-6-40-90-S-NE Racecity-parts 15
-6 AN hose end, straight 555-100001 Jegs 5
-6 AN male fitting to 3/8 tubing 799-639210 Jegs 9
25’ 3/8 aluminum tubing to turbo 555-15100 Jegs 20
1/4 MPT adapter to –6 male fitting 555-100104 Jegs 3
Flange inlet adapter, ¼ FPT Ebay 15
Drain side: 0
Turbo drain flange- 1/2” FPT TPS 15
1/2 MPT x –8 male AN adapter 555-100110 Jegs 4
-8 AN 31” hose, used, 2x90 swivel ends, turbo to pump inlet over axle SS-8-31-90S-90S Racecity-parts 15
-8 AN hose end, straight 555-100002 Jegs 7
-8 AN to 1/2 MPT at Pump inlet 555-100109 Jegs 4
½ FPT x ½ FPT adapter, pump inlet 799-661470 Jegs 12
Electric pump, Shurflo, 1/2 MPT in/out, 3 GPM 2088-313-145 Dultmeier Sales 135
½ FPT x ½ FPT adapter, pump outlet 799-661470 Jegs 12
-8 AN 13” hose assembly, straight fitting/no fitting, pump outlet to tube IC-SS-8-13-STRU-NE Racecity-parts 10
-8 male AN fitting to .5” tubing 799-639230 Jegs 9
25’ .5” aluminum tubing to oil pan 555-15101 Jegs 24
-8 female AN fitting to .5” tubing 799-639230 Jegs 9
-8 AN 26” hose, used, 2x90 swivel ends, tube to drain fitting on pan AQC-8-26-90S-90S Ebay racecity-parts 5
Wiring- 3 rolls of 14 gauge wire, 2 inline fuse holders Advance Auto Parts 15
Shipping, Jegs 10
Shipping, hoses 35
Total 464
I copied it from a spreadsheet so sorry its not all pretty anymore. Hope that gives you some ideas.
50
Jegs 18
Total 2767
Supply side:
Drain side: 0
Shipping, Jegs 10
Shipping, hoses 35
Total 464
I read your post about what you have INTO your car and that's way over what I'm willing to put into mine
. Then again, I dont want to run over 800+rwhp
. I'm looking for something more along the lines of 490-510 rwhp with some nasty torque... 600rwtq+.
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Originally Posted by Boostaholic
I made my twin turbo kit
Your only thinking 800RWHP, I would cry if thats all I got out of it, then spend a lot more money :/
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
-Garrett
-Garrett
I built my own with a used Holset. I'm just under $1000. I'm very happy with it. Check it out at http://www.junkyardturbos.com
Damn man... any numbers? I think I was reading up on your article and it said that you had some problems with the oil settling in the bottom of the turbo when you shut it off or something? Did you find a fix??? Was it just the valve or tha spring? You live in SD, I'm in OC... perhaps able to help me out and I can pay you some?
I made my own remote mount for a V6 Camaro/Firebird. I did not use the same quality parts that STS uses, but it still works great. I think that I put in it all together about
$2000.00 with the intercooler. I wasted alot of money and time on R&D before the kit, but you should be able to do it for less than $1500. It all depends on what components you decide to use. The cheaper the better (for me at least) so used parts can work well (rebuilt turbos, used intercoolers, BOV, Wastegates, ETC.). There is really nothing special about the piping in the kits. You can use the same piping that you find in a muffler shop. It was fun making mine. Good luck on yours.
Damn man... any numbers? I think I was reading up on your article and it said that you had some problems with the oil settling in the bottom of the turbo when you shut it off or something? Did you find a fix??? Was it just the valve or tha spring? You live in SD, I'm in OC... perhaps able to help me out and I can pay you some? ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Originally Posted by DragLS1
I also bought a holset H2D but mine has a vband setup at the exhaust outlet. I am going to build a front mount setup and shoot for ~650 at the wheels. I already have a cam specced out for this combo. I like the idea of using exhaust piping for the intercooler. I am going to upgrade to larger injectors and fuel pump though in preperation for a larger turbo later on. I wonder why your H2D has the bolted flange at the exhaust?
No problem making 650 whp with that H2D.
I'm in Mission Viejo and I work in Irvine. My car is up at superior getting tuned by Shawn Ellis right now, trying to get some of the minor qwerks out of it and adding a couple more deg. of timing. I'm goin up to bakersfield this weekend for a T&T run, so if you know anyone who wants to run up with us, lemme know!!!
Do you mean a conventional setup or a rear mount with an FMIC? I'm not sure what application my H2D was used on to have the tapped flange. I'd rather have the v-band than the bolt exhaust flange that mine has.
