Weird problem
Old Mar 10, 2005 | 09:59 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default Weird problem
I am throwing a DTC 1515 - Electronic Throttle Position Sensor code when I'm at 125+ map and ~5400rpm, regardless of throttle position. I hear an aluminum sounding thunk (and I believe this to be the blade slamming shut), then see the SES, and then reduced engine power in the display.
Now some idiot at GM thought it would be a great idea to disable the TB when this code gets thrown, so its a big problem (the TB can be re-enabled by clearing the code, but not before).
This only started after I installed my FMIC, but I didn't really get to these RPMs after the GT70 but before the FMIC. I'm running a megasquirt which taps the dark green sender wire on the TPS, and mods in the sig.
I do not have a blowoff valve. Could this be the issue?
Old Mar 11, 2005 | 08:14 AM
OnyxSilveradoSS's Avatar
drive by wire sucks!
Old Mar 11, 2005 | 08:43 AM
JERRY2500's Avatar
14 Second Truck Club
Did you used one of those wire tap connectors ? I've had one cut the wire in two before. May want to check that. Or just a bad TPS.
