Cam for p1sc!
Old Mar 12, 2005 | 11:46 PM
CMKworm's Avatar
Exclamation Cam for p1sc!
I currently have a .222 comp cam with 112 lsa and a p1sc kit. The cam is letting all the boost out so I'm barely making 5 lbs. The shop said I needed around 114 lsa. What should I get and what are you guys running?
Old Mar 13, 2005 | 11:35 AM
mdhmi's Avatar
I've been discussing this exact question with a number of tuners lately. Many of the tuners I spoke with recommended an 02+ Z06 cam or the LPE GT2-3 cam for my ProCharger setup. Both cams are excellent for FI and have terrific street manners.
02+ Z06: 204/218 .551/.541 117.5 LSA
GT2-3: 207/220 .573/.580 117.5 LSA
Mark
Old Mar 13, 2005 | 02:04 PM
sr71's Avatar
just 2 degrees difference in lobe seperation isn't going to make a huge difference. I would just leave the cam and pulley the sc up a little bit.
Old Mar 13, 2005 | 09:54 PM
CMKworm's Avatar
I'm already running a 3.2 pulley. I can't go smaller without getting an oversized crank pulley.
Old Mar 14, 2005 | 01:29 AM
disassembled's Avatar
Any stock like cam will be ideal. I have two for sale if you're interested. One is an 01 Z06 cam and the other is a stock 99 LS1 cam. If you want to try and get a bigger cam than stock i suggest calling one of the respected engine builders to see what they have to say. I recommend HPE but i am sure APE, LPE or any of the other sponsors will be able to set you straight.
Greg
