LS1 block Vs LS2 block for Forced Induction
Old Mar 13, 2005 | 08:12 AM
96 Comp T/A's Avatar
Default LS1 block Vs LS2 block for Forced Induction
Hey gents,
Does anyone have experience yet with the LS2 block in a forced induction build? I am getting ready to start a project and do not have either LS1 or LS2 block yet. I am wondering If I should pay what looks to be a $700-800 premium over what a used core LS1 shortblock is going for and head right for the 4" Siamesed bore LS2. How do the ALuminum LS1's hold up to forced induction vs there Iron block counterparts? Is ring seal and bore stability a problem?
Old Mar 13, 2005 | 09:04 AM
smokinHawk's Avatar
i dont think borestability has ever been a problem, but i would like the fact that the ls2 has a 4" bore and you can use hellfire rings on them.
Old Mar 13, 2005 | 09:58 AM
Slowhawk's Avatar
LS1Tech Sponsor
I have a LS2 402 shortblock sitting here waiting to go into a Procharged car with AFR 225's.Should have results in a month or so.
Old Mar 13, 2005 | 10:32 AM
TwnTrboCE's Avatar
The LS2 appears to be a stronger block. But the LS1 has shown to handle power very well. Really depends on what cubes you want and HP goal.
Old Mar 13, 2005 | 03:36 PM
sb427f-car's Avatar
SSU'S Vice Mod
What's the max safe bore on an LS2?
Old Mar 13, 2005 | 04:27 PM
Sam88Gta1's Avatar
The way the sleves are cast into the block is a problem past .020 bore.
Old Mar 13, 2005 | 04:44 PM
sb427f-car's Avatar
SSU'S Vice Mod
Yeah, I'm guessing it's more expensive to press them in?
Old Mar 15, 2005 | 11:11 PM
Casper's Avatar
Question
Why can't you use Hellfire's in an LS1?
Why does the LS2 "appear" to be stronger?
Old Mar 16, 2005 | 05:52 AM
smokinHawk's Avatar
because unfortunatly they dont come in sizes smaller then 4"
Old Mar 16, 2005 | 06:38 AM
SINISTER's Avatar
i will be putting a 6.0 iron block in mine.
could care less about the extra weight ill just skip lunch a few times..
Old Mar 16, 2005 | 06:43 AM
Z06PSI's Avatar
That is alot of lunches....
