New motor w/ turbo on dyno need help
398ci w/ t72 fast system coil on plug 72lb inj. when runing on dyno around 3000 rpm and no load egt goes to 1500 deg. motor sounds good afr 13.9 but plugs look like they are being washed also 15" of vacuum.if wideband is off and motor is fat should make egt's lower?
thanks
thanks
