turbo project for the trailblazer I-6
Old Mar 16, 2005 | 09:26 AM
top end's Avatar
Default turbo project for the trailblazer I-6
i am looking for customizing a turbo for the trailblazer I-6
and the turbo is a garret t04B with 1.15A/R O-trim produces about 450hp
and an external wastegate wich is tial 46mm with a 6psi spring and for the fuel a Vortech FMU with a ratio of 12:1
with an APEXi V-AFC/S-AFC Fuel Controllers probalby i will choose the V-AFC
with a spearco intercooler 29.5*8*3 spec
the piping will be stainless steel and cusotmized and so is the exhaust manifold
any ideas or corrections for this setup and tell me what do you think
yeah and one thing i will keep the oem pistons untill i upgrade the tranny
Old Mar 16, 2005 | 10:58 AM
smokinHawk's Avatar
id like to see this, as i need to talk the girlfriend into turboing her trailblazer.
I'll wear her down eventually
i dont know how the turbo would work with the 4.2L
but if it was me id be looking at a 54mm-60mm with a .83 or .96 AR.
since the engine has a 4+ inch stroke i wouldnt be reving it to high, but make it a torque monster.
the manafold would be somewhat easy to build similar to the supras with their singles, and have the downpipe exit in a similar fasion
Old Mar 16, 2005 | 11:25 AM
dynedta's Avatar
chronic masturbator
the apexi vafc is for vtec engines and the safc is more an import tuner, actually im not even sure it will work your application.
Old Mar 17, 2005 | 12:45 AM
gogogadgetcar's Avatar
I think this is a really interesting project, how well do the heads flow on this motor?
Make sure you don't skimp on the fuel systme or tunning aspect of this project or you'll regret it
Old Mar 17, 2005 | 12:51 AM
Camaro_Zach's Avatar
i have an 02, and i want to do this BADDLY however i gotta finish my camaro first before i start to mod my tb. i would love to turbo it, not just because its a bad *** truck and is fast for what it is, but id maintain its fuel efficiency as well as get some more umph for towing. id definatly buy a kit rather than fab one up for myself when the time comes. anyways i got that 9 year 100k warranty so i got some time before i **** with my daily driver.
Old Mar 18, 2005 | 07:30 AM
OnyxSilveradoSS's Avatar
Hahn Racing has a Turbo Kit for the TB...not much info on the web, but thay had an ad in Trucking...
