Wastegate Actuators
Old Mar 18, 2005 | 05:49 AM
04BlueSS's Avatar
Default Wastegate Actuators
I am in the process of building a twin turbo kit for my Silverado SS. I purchased two off the shelf GT32 turbos with internal gates. The problem is I initially only want to run 5psi of boost but have read that the GT32's have 12psi springs. I thought about swapping a different spring in the actuator except they are a sealed design so I don't believe it is possible. Does anyone have suggestions on the best way to go about achieving my 5psi setting?
Thanks
Old Mar 18, 2005 | 07:01 AM
99Fbody99's Avatar
Thanks
Take a look at the PN#, the sticker is on the back of the actuator.
10364-01* 6.0 psi 0.41 bar 6.3 mm
10364-02* 7.5 psi 0.51 bar 6.3 mm
10364-03 10.7 psi 0.74 bar 6.3 mm
10364-04 12.3 psi 0.85 bar 6.3 mm
10364-05 13.5 psi 0.93 bar 7.4 mm
10364-06 18.0 psi 1.24 bar 9.4 mm
Dave
Old Mar 18, 2005 | 12:03 PM
04BlueSS's Avatar
Dave
There are no stickers on the actuators except a warning label, however there is a number scribed into the top 434133-64 144625 03-182. The numbers are identical on both actuators.
Nick
