building a blower motor, need input opinions
looking at this
LS6 Block
Ported 6 Liter Heads (~72cc)
Diamond -11cc Pistons .927pins coated skirt (maybe coated top?)
Eagle H-Beam 6.125 Rods
stock crank
Callies eh, where can I get those?
I think APE, LPE and Agastino uses these rods in their forged engines too. Good luck.
Kyle
The coating is by Dart........
http://www.automotiveperformance.net/services.htm
Give Chris @ AP Engineering a call he will explain it to you better then i can.
Kyle
i got about 5,000 hard miles between ring sets only making about 900fwhp.
So MM you saying that the rings them selves wont last that long... ie 5000 miles like yours on high HP alone or in a aluminum block??? You see Iron as the same or is that why you switched??
Kyle
I see so many ask for big power numbers yet they are unwilling to take on the responsibility and maintenance that goes along with it.
power doesn't come cheap folks
