Newbie 6.0L Whipple question
Old Mar 21, 2005 | 12:05 PM
WhippledHD's Avatar
Default Newbie 6.0L Whipple question
New to this site so don't beat me up too bad.
Kinda of a general question here for you blower motor guru's...
I have a stock 6.0L motor in my 03 Chevy 2500HD that I put the Whipple 2.3L kit on. I've got about 60,000 miles on the motor total and 30,000 s/c miles on it and it runs strong but at 7 psi and pump gas I know I'm eventually going to have to rebuild the motor. I'll be pleased if it makes 100,000 but know it might not so I want to start planning for the future. So here's my question.....what would you guys do to this motor in the rebuild?? Keep in mind I still need to pass CA smog, sort of....if you know what I mean......I'd still like to run pump gas, premium is 91 octane out here.....and finally what should I be looking at spending for a quality rebuild/upgrade??
Punch it out to 400.....???..forged pistons....????.....8 to 1 compression...???....change the heads..???? ...cam???
Thanks,
Chris
PS The pic below is an old one, I've updated to the newer style Whipple kit with the injectors upstream of the compressor and a custom tuned ECM.
Old Mar 21, 2005 | 12:44 PM
JERRY2500's Avatar
14 Second Truck Club
Welcome to the site, I'm sure some of the guy's will chime in and help you out. Punch it out to 400, forged pistons, 8 to 1 compression, cam. Looks like your heading in the right direction.
Old Mar 21, 2005 | 02:40 PM
WhippledHD's Avatar
Thanks for the "Welcome". Looks like some good numbers for ya with the STS. Still haven't got mine on the dyno yet, maybe this summer.
Old Mar 21, 2005 | 02:56 PM
JERRY2500's Avatar
Thanks, that was before the 02 PCM, IC, 44lb injectors,walbro 255lph , i need to get back and dyno it again.
Old Mar 21, 2005 | 06:14 PM
WhippledHD's Avatar
anybody else?
Old Mar 21, 2005 | 06:20 PM
01_SuperSlow's Avatar
You could also try posting in the Truck V8 Performance section here in LS1tech.
