how much boost can you run on a D1?
I went on the Procharger site and it says in the chart that the d1 can run 30+ #s i call bs on that my pulley on the blower looks pretty small right now i dont see the D1 being efficent with no more then 20#. Does anyone know where i can get diffrent pulleys from besides procharger ?and if i can remove the pulley with the blower bolted in the car?. I know i would at least have to remove the fan shroud but is the pulley puller small enough to fit between the radiator and the blower itself? Oh btw i'm seeing about 13#s at 6k with twin intercoolers i guess thats normal?
There seem to be no belt slip of any kind(took me forever to line up that 12 rib belt
) but i think i finally got it straightthanks
Those are some nice numbers, are you doing the tunning your self if not who in the area do you have helping. Sorry cant help with any question Im not running but 10# and have a Pontiac, Good luck and have fun.
now i'm only seeing nothing but 13. 1FASTLS, boost is fun once you get it tuned your right. I put together a setup for a guy right around you, ATI D1SC at 8 psi, and mild cam, stock heads 550 rwhp after tuning it at Heffners dyno. Sounds like your building a stout setup too!
oh dont forget to find out for me about that 20# pulley focker
1. How high are you spinning the motor to?
2. What size is your crank pulley?
3. How big is your blower pulley?
With that we can figure out how fast your spinning the blower and how close you are to maxing it out.
Kyle
Kyle
I believe my Crank Pulley is 7.750 and I know my SC pulley is a 3.4 8-rib.
Kyle
Kyle
Kyle
Kyle
We will see how much boost ya make mark.... you will be close to maxing out the D1.... 62K RPM max and you will be at 61,680 @6600 rpm.
Kyle
today it went 11:50@124mph 2.0 60ft sorry i got a 10 bolt still with auto gears 3.23s on a 6speed car
1/8 was 7.1@98mph i'm going to try what the car dynos without the orange dryer hose also i need a msd box since i dont have one i think we are blowing the spark out.
i'm going to call ati tomorow to find out what my pulley size is. I"m spinning the motor to 6200 right now, i have 1 3/4 hooker lts with a 4" yipe mufflex 4" exhaust with a bullit muffler and a dump. so my exhaust side is fine my heads flowed 278intake/238 exhaust 81% intake/exhaust ratio so i'm pushing the air out fast but i dont think i'm pushing enough of it in and defanatly aint pushing it fast with 3.23s and a 6speed
i'll keep you guys posted , i'll try to put a msd box next week/ smaller pulley, and pull the orange dryer hose off and take it back to the dyno.
15 psi + 383ci + good gas = low 10's I would think.
I went 10.3@136 with belt slippage, it was about 14 psi.
