little help needed in cam specs
Old Mar 21, 2005 | 12:28 PM
SINISTER's Avatar
Default little help needed in cam specs
just recieved a mti 6.0 iron block 370
with all the love
the cam thats in is a 228-224-589-588 on a 114+2 lca
how is this cam going to do with my tti t-76 single turbo
itmder whatcha think?
Old Mar 21, 2005 | 06:16 PM
SINISTER's Avatar
any one???
Old Mar 21, 2005 | 07:12 PM
Got Me SOM's Avatar
looks like it'll work to me, depending on where you want to make your power at.
Old Mar 21, 2005 | 07:15 PM
Revelation222's Avatar
with all the love
Looks just about perfect for a street/strip set up to me.
Old Mar 21, 2005 | 07:37 PM
SINISTER's Avatar
awsome.....
do you think it be a good idea to take the 2 degrees out of it????when i put it back in ????
since im running 373 gears??
Old Mar 22, 2005 | 01:25 AM
awsome.....
I would install it straight up and see where that puts your peak at. Once you get your set up fine tuned with the turbo, etc. Then you can play around with the advance if you really want to. Most likely you should be good as it is. As far a the gears, you will have to adjust all of that according to track (1/4 or 1/8), size of tire, etc. if you want to set the car up specifically for racing.
Im sure there is somone here who can crunch the numbers for you and tell you right around where your peak would be with those cubes and that cam.
IM horrible at math and I wouldnt want to forget to carry the 1.
Good luck with your setup. Sounds like it should be fun.
Old Mar 22, 2005 | 09:22 AM
SINISTER's Avatar
sounds good by me....
thanks guys for all your info!
Old Mar 23, 2005 | 12:51 AM
amwellls1's Avatar
sounds like good advice
