Anyone Know Anything About This Turbo Kit
Old Mar 29, 2005 | 01:30 PM
WS6Guy25's Avatar
Default Anyone Know Anything About This Turbo Kit
I am looking to boost at no more than 8 Psi. Anyone know if I am going to need an intercooler? If so where would I get one for the TA. Also and thoughts comments or suggestions I would like to hear anything you have to say thanks.... Oh Ya I have a 2001 Trans Am WS-6 Ram Air M-6.
Turbo Kit *(STS)*
Old Mar 29, 2005 | 01:35 PM
~RedLineLs1~'s Avatar
Do a search...theres a crap load of info on the STS kit. I would use an IC for 8psi for saftey reasons. You'll also need some fuel accessories (pump, injectors, etc) Not quite sure which ones...but some of the sponsors to the right sell IC kits. How much are you willing to spend? Phamspeed makes a budget kit for a lot cheaper now. If you dont have a limit, look into the TTi, PTK, and Phamspeed kits and see which one you like the most.
Old Mar 29, 2005 | 01:54 PM
Armageddon's Avatar
...with cheese.
Old Mar 29, 2005 | 04:23 PM
HellRaiser's Avatar
Originally Posted by Armageddon
Old Mar 29, 2005 | 04:29 PM
bradyb's Avatar
The STS Methanol kit will cover you intake temps and fuel for only about $500. Get the dual stage boost controller so you can drive around town at 5 psi and switch to 8 Psi when ever you want. You go from 400 rwhp at 5 psi to close to 500 rwhp at 8 PSI with Meth. With clean injectors and a fuel filter you can get away with 5 PSI on the stock fuel system. If you want to run more boost a set of 45# injectors will provide some safety.
Old Mar 29, 2005 | 04:33 PM
HellRaiser's Avatar
Look at this thread. https://ls1tech.com/forums/forced-induction/297659-ken-s-sts-cartek-gto-running-10-68-122mph.html That's all that has to be said about the STS kit. THEY WORK.
Old Mar 29, 2005 | 04:53 PM
bradyb's Avatar
Also, here's an example of the pains of doing a standard front mount turbo kit:https://ls1tech.com/forums/showthrea...4&page=6&pp=20 two weeks and he's not even done yet, poor guy.
The STS kit bolts on in 3-6 hours!
Old Mar 29, 2005 | 05:19 PM
HellRaiser's Avatar
That's because he doesn't have the all the part's yet. I don't think he even has the ic pipe's yet.
Old Mar 29, 2005 | 06:06 PM
According the John, you should be able to bolt up the budget kit just as fast as an STS kit. Both kits should be pretty easy to install considering you dont have to touch the stock exhaust manifolds. The most difficult part in any install would be the oil lines IMO.
BTW, are you done with your install hellraiser? How much longer until you get it tuned?
Old Mar 29, 2005 | 06:13 PM
bradyb's Avatar
WS6Guy, you're out of MA? You're never going to pass emissions/inspection with a front mount turbo kit. You'll pass with the STS kit because it is a cat back system.
Old Mar 29, 2005 | 06:24 PM
HellRaiser's Avatar
LOL I wish I started the install. Still have to get my fuel system, ic pipe's,clutch,gauge's,plug's and wire's,HP tuners,Labtop,wideband,BOV, exhaust pipe and muffler, intake pipe and filter for turbo, valve spring's, EGR block off plate, and I am sure there is stuff I forgot to mention.
forgot snow water/meth inj. kit
Old Mar 29, 2005 | 06:35 PM
Looks like your list wont be ending anytime soon
Old Mar 29, 2005 | 06:38 PM
HellRaiser's Avatar
That's cause I can't stop adding to it . I need to set a limit for myself. But everyday I see something else I want for the setup. I think I might have to go to meetings for people that put to much money into thier car.
Old Mar 29, 2005 | 06:42 PM
"my name is xxx, and I'm addicted to boost" I can see myself being in that boat too.
Old Mar 29, 2005 | 09:45 PM
EightBall's Avatar
Turbo Kit *(STS)*
hey, if you're in Andover, you should come on over to Worcester to check out my project I think it might be of interest to you...I go to WPI...
Old Mar 29, 2005 | 09:55 PM
MIGHTYMOUSE's Avatar
sts.. this sounds interesting.. so the turbo is in t back rather than in the front?
Old Mar 29, 2005 | 10:44 PM
WS6Guy25's Avatar
Ya I geto ut of school in like 3 or 4 weeks than I will be around and ****. Do you go up to the track epping at all?
Old Mar 30, 2005 | 12:42 AM
Armageddon's Avatar
...with cheese.
Yea... seems like it'd lag awfully bad, or somebody could just about walk away with your turbo. don't see how it works at all...
Old Mar 30, 2005 | 01:07 AM
MECHAM's Avatar
I wonder how efficient it is to run the turbo way back there?
Old Mar 30, 2005 | 01:33 AM
Wildman's Avatar
I wonder how long we have to
Oh yeah:
STS/Cartek GTO running 10.68@129.81MPH
I guess it's not very efficient.
**Yawn**
