Multi Boost Levels?
Old Mar 31, 2005 | 07:08 AM
KraZy's Avatar
Default Multi Boost Levels?
I have a stupid question.....
How are we going to be able to set multiple boost levels in our cars? Would we have to tune the computer for each boost level and save the edit....then load it when you change the boost w/ the controller?
My Procharger is off and sold, been thinking about going turbo.
While I'm at it, you think my Vig 3600 multi disc is going to be too much stall for a turbo?
Old Mar 31, 2005 | 09:04 AM
RyanJ's Avatar
SSU Moderator
What you said is right. Or you could get a map-based set up like HPTuners 2 or 3-bar SD tune or an aftermarket pcm like Big Stuff or FAST. Then the pcm senses boost and adjusts for it given what you've programmed. Then you can just turn the ****.
Old Mar 31, 2005 | 11:39 AM
KraZy's Avatar
Well that stinks.
