WTF STS?! Look at this...
Old Apr 3, 2005 | 03:09 PM
Third Gear's Avatar
Originally Posted by 2002nhraformula
wow how did i get this 4 inch pipe threw when you are having problems with the 2.5 pipe hehehehe i had to sorry
george
try going the same way first . Plus the MAF right there is 4"... that's the main problem. They should have made it like the LT1 kit.
Old Apr 3, 2005 | 03:19 PM
07BlueDevilZ06's Avatar
it is actualy less then 4 i think its 3.875 cutting is required and fab work to put iin the kit i did
george
Old Apr 4, 2005 | 12:04 PM
boosted99camaro's Avatar
I dont get it why is everybody changing their exaust pipe back to stock to in- stall the sts just order it for the larger pipe.
Old Apr 4, 2005 | 03:40 PM
Third Gear's Avatar
First, I didn't know about the exhaust until I already had the kit. If it was just a matter of size, I would have the pipe expanded. Second, the I-pipe I have is not bent the right way. The STS inlet pipe extends PAST the bend in the I-pipe. I don't want to butcher the STS pipe. It has to be removable until it gets CARB approval. I have to get smogged in a year, and I'm not sure if they'll have it by then. They should according to STS, but I don’t want to assume anything. Once I weld it, I don't want to take if off...
