Turbo Intall -- more updates
All the popular fitting manufacturers (earls, aeroquip, etc.) make metric to AN adapters, which SHOULD work. Aeroquip even makes one with an O-ring seal -- which looks like the best bet to make sure it doesn't leak. I was told all the big stuff wil be done by friday..... im always pushing for pics..... maybe friday ill have some.... Soon now....... Rearend will be ordered and BS3 will go in.... and we are going to use the stock gauges since you figured it out. Thanks again.
Kyle
FYI, with stock motor mounts you will need a lot of clearancing. With the poly motor mounts you will still need some significant clearancing. My YSi is right down there too and we did more clearancing than we anticipated. The blower torqued up enough to brake the oil feed fitting
Kyle
