Tt Sbc 327
327 LJ
splayed caps,
forged LJ 68 vette crank
Forged Eagle 3D Hbeam rods
Forged 8.5-1 Vinolla Pistions
looking to byu afr 210s
any help
thanks Willie
Thanks for the help guys
Id look at nothing less than a T76 w. a .96AR exhaust side. There are many different trims to look at as well and will depend on the manufacturer. Garret makes a line of "GT" turbos that work well and are packaged fairly small for the amount of power they pack.
Check out these guys for some help
www.forcedinductions.com
Also, what do you plan on using for engine management? EFI? carb? camshaft? and What about headers?
If you are really serious about spinning the engine that high, you are going to need a pretty tough valvetrain. Hope you have some deep pockets.
Good luck!
The cam is my last worry at this point i want to have all the specs of the turbos and what not b4 i get that.
when you blow their doors off fomr a 70 roll is fun (only seen vids of that though
Oh and goodluck on your build, wicked.
That's why I've been thinking about a 382~388 built on an LS2 block cleaned up at near max safe bore, hydro roller @ first, switched to solid roller, and two 61s, 63s, or 67s
You don't want a GT60 series, that's on the big frame. If you're looking to go GT series, look @ the 30s and 35s. They should be pleanty of turbo. 61s or 67s in a P trim will probably good enough. Of course Jose would be the one to ask. Call 'em up, they're there to help.
