Min/Max angle for turbo oil drain?
Old Apr 4, 2005 | 09:46 PM
EightBall's Avatar
Default Min/Max angle for turbo oil drain?
What is the angular range at which the CHRA should be oriented for the safe drainage of the oil from the turbo?
Old Apr 4, 2005 | 11:18 PM
gogogadgetcar's Avatar
the book of turbo knowledge says......
between 5 and 7 o'clock and to have the drain above the oil level
Old Apr 4, 2005 | 11:51 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Typically you want no more then 45 degs from straight down.
Jose
