max boost, power with sts t60-1
Old Apr 5, 2005 | 11:29 AM
boosted99camaro's Avatar
Default max boost, power with sts t60-1
just wondering what would be the max hp and or boost the t60-1 from the sts would support .
Old Apr 5, 2005 | 11:40 AM
NOSjohn's Avatar
Restricted User
Off the top of my head, you're probably looking at 500-550hp crank...with big boost numbers (27+).
Old Apr 5, 2005 | 11:44 AM
smokinHawk's Avatar
T60-1 wouldnt support 27 psi.
you might see about 380rwhp with that setup.
Old Apr 5, 2005 | 11:57 AM
Blackbird's Avatar
what? 380rwhp???
boosted -your refering to the base sts kit turbo right?
if so a few folks have made 500rwhp. 12-13psi if I remember correctly.
the power drops like a rock above 5k though.
if you search this and the other board you may be able to dig up some graphs.
I saw them about 6+ months ago or so, when STS was just coming on to the LS1 scene
Old Apr 5, 2005 | 12:04 PM
gogogadgetcar's Avatar
I remeber a few people on here posting numbers in the high 400's
Old Apr 5, 2005 | 12:08 PM
Blackbird's Avatar
http://www.ststurbo.com/ls1_5_psi_vs_8_psi
Old Apr 5, 2005 | 12:54 PM
thanks I was just wondering because I want to put a turbo cam and some springs in wasjust courous if was possible to make 550 or so im at 500 now on a dynojet.also was wondering can you upgrade the standerd 60-1 for more hp so it doesnt fall off early or will I have to get the gt67.
Old Apr 5, 2005 | 01:03 PM
Blackbird's Avatar
you could experiment with a bigger exhaust housing.
that would be your least expensive route.
or as you mention, jump to the 67 and make over 600rwhp if you want to.
Old Apr 5, 2005 | 01:05 PM
NOSjohn's Avatar
Restricted User
Sorry, you are correct. As I stated, I was going off the top of my head. It would support 63lb./min. at 25psi. Thank you for the correction smokin'. However, I think you RWHP numbers are a little off. Maybe?
Old Apr 5, 2005 | 01:11 PM
Assassin's Avatar
what is your exhaust housing now?
Old Apr 6, 2005 | 01:19 AM
F8L Z71's Avatar
12 Second Truck Club
380rwhp???? Man talk about a hater... Why do you even bother posting in these threads when all you seem to do is bash? i usually don't run in to stick up for STS on crap like this but I've noticed you always come in with a negative response and it's kind of annoying.
Old Apr 6, 2005 | 01:22 AM
F8L Z71's Avatar
Too answer your question. I have seen a guy in Texas, I think Cole is his name, dyno a stock 5.3L truck with 15psi and make a peak of 512rwhp on the 60-1 with no IC just methanol but it was a VERY spikey graph and fell flat on it's face after 5200rpm.
Old Apr 6, 2005 | 05:07 AM
MelloYellow's Avatar
25psi on an LS1?
460-500rwhp might happen for a small turbo.
