Few more D1SC/SDCE/FMIC progress pics
Old Apr 14, 2005 | 01:11 PM
Cyborg's Avatar
Looks nice
Old Apr 14, 2005 | 02:11 PM
Fierce-LS1's Avatar
what about the 2 1/16 gauges ? How would those fit
Old Apr 14, 2005 | 02:16 PM
2K2CamaroSS's Avatar
what crank pulley are you using? ATI or Stock?
Old Apr 14, 2005 | 02:56 PM
kp's Avatar
kp
Keyed stock crank pulley for now.
2 1/16 guages are a little small but you can cut a round piece of plastic and then cut a 2 1/16 hole in the plastic, thats what I am going to do with the wideband (innovate XD1) whenever it gets here.
Old Apr 14, 2005 | 03:04 PM
CHRISPY's Avatar
Originally Posted by kp
Got the pipes back from the coater today so its pretty much done under the hood and inside (except for the roll bar/harness), even did the initial tune to turn off the the A4 codes and other non-running type stuff. All I need is a trans and driveshaft now
I like how you used the longer pieces of silicone on the pressure side. Looks great!
Old Apr 14, 2005 | 03:11 PM
Thats the 8 rib SDCE pulley attached to the stock balancer then, right? If that's the case it looks totaly differnt than the one I recieved.
Old Apr 14, 2005 | 03:55 PM
kp's Avatar
kp
Thats what it is, they may have changed it somewhere along the line. The one for the ATI damper bolts on with 3 bolts.
Old Apr 14, 2005 | 04:59 PM
NA$TY-TA's Avatar
Thats the same crank pulley i had also...... maybe your confused because of the way he bolted it up...
Kyle
Old Apr 14, 2005 | 06:34 PM
Well the one that shipped with my 8 rib is a two piece pulley. It's held together with 3 bolts. From the angle in your pic its hard to but I have about half and inch between the pulley (SDCE doesn't fully go inside the stock pulley). Do you have the same gap?
I think I like the one piece a lot better!
Old Apr 14, 2005 | 10:29 PM
kp's Avatar
kp
There is a little gap between the balancer and SDCE pulley, not quite a 1/2" but maybe 1/4-3/8 inch.
Maybe they are doing that so you can switch to an ATI damper down the road w/o buying a new pulley.
Old Apr 14, 2005 | 11:16 PM
frcefed98's Avatar
Yep, SDCE designed the new crank pulley so it could work with either the stocker or an ATI dampner....Kev has one of the first set ups....
J
