low maf freg?
Old Apr 14, 2005 | 01:39 PM
KAOS's Avatar
Default low maf freg?
what causes this? checked the codes and not sure what the number was but thats what the guy at advace said anyway is it bad or maybe just.... what?
Old Apr 14, 2005 | 02:48 PM
MECHAM's Avatar
replace it
Old Apr 14, 2005 | 03:14 PM
Scalpel's Avatar
That'll cause idle and running issues if it's bad.
Old Apr 14, 2005 | 03:54 PM
KAOS's Avatar
i think i know somebody that has one lying around,
Old Apr 14, 2005 | 06:01 PM
nbm00ws6's Avatar
Check your ground connections also, both where it connects to the maf and grounded to back of the head.
Tom
Old Apr 14, 2005 | 09:26 PM
KAOS's Avatar
going to look friday
Old Apr 14, 2005 | 09:42 PM
Bad30th's Avatar
Also might try carefully cleaning the MAF wiring internals with some rubbing alcohol and qtips.
Cheers,
Bad30th
Old Apr 14, 2005 | 10:27 PM
highspeedspecialist's Avatar
whats your reference voltage? I think it should be a 5v ref..not sure...
Old Apr 15, 2005 | 08:05 AM
KAOS's Avatar
Originally Posted by highspeedspecialist
whats you reference voltage? I think it should be a 5v ref..not sure...
do you just use a regualar volt meter. i'll have to look at that
Old Apr 16, 2005 | 01:04 PM
yeah a volt meter will work...
