STS tunes please?? using HPTuner
Old Apr 18, 2005 | 02:42 PM
ssdriver27's Avatar
Default STS tunes please?? using HPTuner
hey everyone, I just ordered my HPTuner over the weekend. I am installing the STS remote turbo so this is the reason I went with the HPTuner. Please if anyone out there has a STS system and has a good tune please please please share ??? Im going with the basic 5psi , 60-1 setup and I am bone stock 2001 Z28 M6 ( well bone stock spet for the sportline suspension and the pollished Z06 wheels chromemolly pandhard and 3 point shock tower brace ). Thanks for your replys and happy motoring.
PS: yes I posted this in the tune forum too.
~Guy
Old Apr 18, 2005 | 03:25 PM
quicksilverado's Avatar
do you have alky injection or an intercooler to go with this?
Old Apr 18, 2005 | 03:39 PM
ssdriver27's Avatar
nope. sure dont. no need from what I gather unless I up the boost at which time I will rather upgrade the injectors and tune away.
Old Apr 19, 2005 | 01:34 AM
ssdriver27's Avatar
come on noone ?? wth. Nelson performance wants 250.00 for a damn .bin file . shoot when I get my HPTuner I will be helping anyone who is interested get their **** tuned. I cant even get a reply ?? hmmm.
Old Apr 19, 2005 | 08:59 AM
John_D.'s Avatar
I don't know because I'm just about to cross that bridge myself.
I have heard that with higher boost levels folks are running around 15 degrees of timing advance. And that with lower levels they're getting by with 20 degrees.
So that's a start.
As far as changes for a/f ratio - don't know about that. I'm running heads and cam already, and am going to 60lb/hr injectors, with a vacuum referenced fpr, so my fueling won't be any help for you. I do know you need to go richer, and you can set that up by tweaking the PE numbers at the upper end of the scale.
Old Apr 19, 2005 | 04:06 PM
red91z's Avatar
LS1TECH Sponsor
Mine actually peaks at 16 degrees of timing but I will be running 8psi with meth. I'm going to be using the speed density software now though.
Old Apr 19, 2005 | 05:30 PM
greentahoe's Avatar
Ive had a hard time finding .bin files as well. You may need to get on a dyno. Thats only around $60. You then use your PE vs RPM table to dial in AF. I would start at 13* and see if you can add a little more.
Old Apr 21, 2005 | 12:48 AM
ssdriver27's Avatar
thanks for the advice guys the more I hear and read the more I am learning and I pick things up quickly I think I will be able to get it pretty close then go in and dyno to fine tune using their wideband. again I appreciate the help.
~Guy
Old Apr 21, 2005 | 12:29 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Guy, the problem you'll face is that most of us have tunes for higher boost + meth, etc.
My advice is to start out very conservative and take your time. Start out really low on the timing, like 10* max for the boost range, and work your way up. You might want to do a good MAFless tune prior to putting on the STS kit.
