Can a CAM lift heads
The specs on the CAM are as follows...244/ 248 651/ 615 116. The builder from this other shop and the shop re-doing the heads are saying that this CAM is creating too much cylinder pressure. My issue is that the Tuner and my builder say that this CAM should work. To add suspense - two different guys at CompCam can't agree - one says yes, one says no.
So, with that being said - I'm going to have to ask for the help of others. Here are the engine specs...cast iron 6.0, Callies crank, bore 30 over, stroke 4", -30 cc pistons, stage 3 heads 70 cc - compression should be around 8.7:1. ATI twin intercooled 15 psi, ARP pro series studs.
Here is the CAM that the guy doing my heads recommended (I think it is too small) - 222/ 230 566/ 572 114+2. The CAM that I like is...232/ 236 591/ 601 114+2.
I'm looking to make over 700 rwhp, if possible. Need professional input...
Correct, but I have had a lot of problems with this setup. I need help with which cam to pick. By-the-way, I'm runing 15psi now.
Someone please help...
The cams being recommended sound way too small for your 408, mainly the duration IMHO. Stick to a .240+ duration and definitely keep the LSA at 114 or larger for your turbo application. The lift at or lower than .600 should be sufficient.
I would like someone to give me the specs of a cam that someone else has had sucssess with on a similar application - I don't want anymore experiments.
If you are running 15 pounds of boost and are getting the heads reworked, I would defiantely have them o-ringed.
Keith
