Top numbers for STS base turbo?
Old Apr 20, 2005 | 05:04 PM
PilotMan's Avatar
Default Top numbers for STS base turbo?
I called and spoke with Brady today at STS, his 02 LS1 put down 492 rwhp and 550 pounds of torque with the stock 60-1 that comes in the STS kit. Brady says his car is 100% stock so he's using methanol as fuel and as an intercooler at 8 PSI. He said his power was dropping above 5,000 RPMs because he was maxing out the turbo. Do these numbers seem correct?
I'm thinking about getting a GT67 turbo for my Fbody and am wondering if it's a big enough difference over the Ptrim 60-1 that I have now. I want to hit 500 RWHP at 8 PSI with my car. I have an 02 Z28.
Thanks!
Old Apr 20, 2005 | 05:07 PM
Blackbird's Avatar
yes, the 67 will take you into the 600's from what I have seen.
if you want more than 450 to the wheels it's time to step up.
thats why I went 67 from the get go.
Old Apr 21, 2005 | 09:52 PM
NYSS Guy's Avatar
I hit 475 rwhp with the base 60-1, but it does fall off pretty hard above 5k. I agree with Blackbird, if your goal is over 450 rwhp, it's probably best to get the 67 from the beginning.
Old Apr 21, 2005 | 11:37 PM
quicksilverado's Avatar
I've got the 67 on the 5.3 in my truck and I made 400 to the wheels at 5psi and methanol. You should make 500 rwhp with the 67 and 8 psi on a 5.7 with no problem.
