Boost referenced regulator users
A little info about my car:
Im using a custom fuel system with sumped tank, aeromotive rails off a Mustang, and 13101 regulator. Im using this setup with a 5115 NOS dry kit for a Mustang that uses vacuum spiker to bump the fuel pressure up at the regulator on the vacuum port. Right now I am using a scared IFR table. My car is going pig rich as RPMS increase because I think im actually seeing that the injector is opening more as RPM increases based on the scared table. If I can eliminate the scaled table for one more constant and I can start to adjust fueling and have a more accurate A/F graph instead of going richer as RPMS increase. I know that right now im spraying through my MAF and it also will add fuel based on load.....I wil be moving the dry nozzle behind the maf and adjust my timing table accordingly because I will be getting fuel from a manual source off the nitrous kit itself with the spike of the regulator.
Any help is appreciated....I know once I get these last 2 things straightened out the car will pick up even more power.
Right now its making 616hp and 790tq with it going 10:1 as soon as the nitrous is activated...It stays that way all the way across...Not sure what its actually seeing with the scaled table either because the wideband graph doesnt read anything below 10:1..hehe
If I can lean it out I feel there is about 50-70 hp left in it...this is all on stock heads and stock shortblock btw.
Cam only setup.Mike
i dont know what this 'vaccum spiker' will do to your tune but off the gas should be close.
I have edit so I should make the whole table read that value then right?
Mike
Mike
Starting mid 5 range had me off the scale rich after starting w/ a dead nuts setup from the 8.1 marine injectors.
Just my .02 from getting the truck back up and running
i ran 5.5 per cablebandit on a 1/1 regulator with svo lime green tops.. if you dont have those then i dont wanna guess.. maybe you have these ones matt is speaking of and they require a diff flow.. but yes it should be the same number if your regulator rises 1/1
-7% is all good and fine, but when the trims zero in PE you get that 7% fuel back. If you trim the PE to get where you want to, it's about 7% leaner than you expect. If something happens fuel flow wise, voltage, etc and your trims manage to go back to zero or positive, now your PE airfuel is a magical 7% lean.
I like zero or slightly positive fuel trims simply because I know what the PE airfuel is gonna do then.
Just my preference.
Harlan and MM, yes they are the Lightning green tops...
Ill look into what you are working with Matt and I am assuming that im chaning the whole table to the one number you are mentioning...thats the only thing i dont guess has really been verified yet. Yes the reg...is 1:1
Mike
i have HPT is this what i modify, those values are near 5.5 or 5.9? is that ls1edit units?
Mike
Mike
yup have close to the same values now.
Mike
