C5 PTK TT #s
Old Apr 26, 2005 | 08:38 AM
NA$TY-TA's Avatar
Can we get some pics..... im pretty sure ive seen them before on the corvette forum but it would be a nice touch to this thread.
kyle
Old Apr 26, 2005 | 09:53 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Here is a file with Kevin's buildup pics.
http://forcedinductions.com/images/PTKC5TT/
Old Apr 26, 2005 | 10:43 AM
MIGHTYMOUSE's Avatar
i run tr6's at the gap they came at.. stock coils and stock plug wires.
if you have aftermarket plug wires on then change them back.
Old Apr 26, 2005 | 10:50 AM
LS1TECH Sponsor
David I have heard that before about using stock plug wires, but I haven't had anyone confirm it. Guess the stock plug wires are pretty good afterall.
Old Apr 26, 2005 | 10:54 AM
i have had trouble with aftermarket plug wires at high loads like these..
accel also sent me a set of wires that worked fine that were on the car at 830rw
Old Apr 26, 2005 | 11:52 AM
1KHP's Avatar
What kind of work do you have to do to the ls6 block to handle big power in boost? Should you sleeve it?
Eric
Old Apr 26, 2005 | 12:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd close up the gap to .030 first and see if that helps, sounds like an ignition problem to me. One of the truck coils (there are 2-3 styles) are hotter than the stock car coils.
I run truck coils and MSD truck wires and have zero ignition problems.
Old Apr 26, 2005 | 12:43 PM
Shinobi'sZ's Avatar
I will do both...regap the the plugs and go buy some stock GM truck wires...I need the longer ones with my coil packs relocated. Thanks guys!
Old Apr 26, 2005 | 01:16 PM
SUPER DAVES Z's Avatar
Eric
Just drop in some good pistons, rods and apr studs. The stock block and crank have held up to 8.20's at 170mph so they're good for a lot!
Old Apr 26, 2005 | 01:29 PM
1KHP's Avatar
What about the ls1 block? Is it alot weaker than the ls6???
Old Apr 26, 2005 | 01:34 PM
Shinobi'sZ's Avatar
All blocks after 2001 are the same.
Old Apr 26, 2005 | 02:00 PM
  #32
2000 Tran Zam's Avatar
i thought only some of the 01+ were ls6 blocks, and others were ls1 blocks?
Old Apr 26, 2005 | 02:07 PM
  #33
1KHP's Avatar
What about the ealier blocks then, are they alot weaker?
Old Apr 26, 2005 | 10:08 PM
  #34
Louis's Avatar
gap them down to as little as 20 to see if it clears it up. This typically occurs at 27+ psi.
I have seen TR6s as high as 40 or 50.
Also, youll definately need a colder plug as well.
Old Apr 26, 2005 | 10:35 PM
  #35
solobaric's Avatar
Great numbers man!
Old Apr 26, 2005 | 11:09 PM
  #36
Shinobi'sZ's Avatar
I wouldn't call the earlier blocks a lot weaker. The main difference between the blocks is the way the windows are cut into the case at the bottom of the cylinders. It allows each cylinder to breath better, which is more efficient, which makes for more power.
Old Apr 27, 2005 | 02:39 AM
  #37
pdd's Avatar
pdd
sick ride bro
Old Apr 27, 2005 | 03:28 AM
  #38
Demonicbird00's Avatar
i wish they made a TT kit for the fbody
ps nice numbers!!! what mods do you have?
thanks
brandon
Old Apr 27, 2005 | 07:23 AM
  #39
NA$TY-TA's Avatar
thanks
brandon
His mods were on the first page......
