Q's on Turbo Tech T-76 kit
Old Apr 28, 2005 | 09:07 PM
StoleIt's Avatar
NKAWTG...N
Default Q's on Turbo Tech T-76 kit
I'm looking into buying one used. The member sent the turbo out to get refreshed or whatever its called, and would be getting it back in two or so weeks. Anywho, it has an A2A FMIC and thats pretty much all I know about the kit. I'm just curious, I've heard that you lose the A/C with this kit. Fact/Fiction? Also wanna make sure it keeps PS and heat and stuff. How hard was install? Since this is used kit I can be safe in assuming there would be practically zero fabrication, correct? Just weld the DP to the exhaust?
Thanks!
Old Apr 29, 2005 | 05:52 AM
smokinHawk's Avatar
well first off, is it the street kit or race kit. those are two completly different kits.
street kit keeps ALL accessories, race you have to remove the AC.
turbo tech does a good job with there kits as you dont have to fab anything to get them in, most go in with little tweaking as well.
im gonna say that kit is a street kit since it comes with the A2A, the race has an A2W but some have got the race kit from speed inc with an A2A
anyways its not a bad kit if you want all your accessories, but this kit is only designed to support a max of 550-600rwhp
Old Apr 29, 2005 | 10:12 AM
StoleIt's Avatar
NKAWTG...N
ya i think its the street kit. can you just swap out the turbo if you eventually want more hp? whats the limiting factor of the kit?
thanks
Old Apr 29, 2005 | 12:31 PM
eviltwins's Avatar
The poor header design, it uses a log header and the other bank of the motor feeds through the back of that log and into the turbo. Very restrictive.
Old Apr 29, 2005 | 12:38 PM
StoleIt's Avatar
NKAWTG...N
ooo log...thats one of those words i didnt want to hear.
Old Apr 29, 2005 | 05:09 PM
StoleIt's Avatar
NKAWTG...N
how much would a used one be worth? any one throw out some numbers.
also, how would the log style compair with phamspeeds stock manifold style?
Old Apr 29, 2005 | 07:45 PM
Unusual T/A's Avatar
I've seen some go from 3k -3500.
