STS turbo oil leak.
Old Apr 30, 2005 | 11:09 AM
sagres's Avatar
Default STS turbo oil leak.
Well me my car is well on its way to being done soon, but I have a problem with the turbo. The thing has less than a thousand miles on it but it leaking into the intake see all the wat thru the pipe from it. Anyone know what in the turbo is causing it. I am going to give STS a call tomorrow, just been hering I am not the only one having this problem. STS bashers please stay out if you have no good input. I am totally happy with the kit. Anyway, anyone else have this problem if so what did STS do about?
Old Apr 30, 2005 | 06:24 PM
trtturbo's Avatar
Its not a big deal. I sent you a p.m. on what to check.
Old Apr 30, 2005 | 07:17 PM
kbracing96's Avatar
I would like to know this too, as I think mine may be leaking too.
Old Apr 30, 2005 | 11:06 PM
Jammer's Avatar
Could just ditch the pcv system and use breathers.
Old May 1, 2005 | 02:52 AM
SuperSporttruck's Avatar
i have that problem also, i would like a fix it tip, if someone knows whats up, thanks
Old May 1, 2005 | 10:06 AM
trtturbo's Avatar
If I understand his problem, he is getting oil in the charge pipe from the turbo.
More than likely, the check valve is bad. Just take the steel braded line off; take the check valve off(3" brass cylinder on top of the turbo); put the valve back on the line and start the car until oil flows and turn it off. After a minute or two, it should not drip anymore. If it does, it is dripping into the turbo as the car/truck sits and running into the compressor and turbine sides.
Old May 1, 2005 | 12:29 PM
Silver02Z28's Avatar
I had the same problem with my DIY kit. I put a check valve with a .3 psi cracking pressure in. That solved it.
Old May 1, 2005 | 12:36 PM
trtturbo's Avatar
They have a check valve already.
