What heads are you using for TT??
Old Apr 30, 2005 | 12:49 PM
extremecorvette's Avatar
Question What heads are you using for TT??
I had a chance to get a set of C5R heads with intake, rockers, lifters, and TB for 3500. I made my frist mistake by waiting 10 minutes to call the guy and he sold them 2 minutes before I called. :banghead:
I'm looking at for heads for a 427 turbo car
AFR 225
LS7
Old Apr 30, 2005 | 01:11 PM
ABeasst's Avatar
it doesnt really matter unless you want every last bit of HP...when you're stuffing a lot of boost in heads arent as important as in NA
Old Apr 30, 2005 | 01:16 PM
I understand that you can just up the boost and but there is a point you can max out for pump gas and with a Darton block I don't want to go to high.
So far I like the TEA Stage 3 heads and there coming out with better flowing heads soon. Cost 3200
I should have got the C5R heads with intake but I waited to long. They would have saved me around 1K
Old Apr 30, 2005 | 10:43 PM
mdhmi's Avatar
If you're not planning on back-halving the car I wouldn't bother with big dollar heads on a 427 TT setup. JMHO.
Cheers,
Mark
Old Apr 30, 2005 | 11:00 PM
Jammer's Avatar
C5R heads would be a tough choice for turbo...high boost like low compression, with such small cc chambers such as on C5R heads, your pistons would be dished like a dixie cup..,
Seriously, you probably want 6.0 heads or ls6 heads, or better yet, the AFR 225's.
Old May 1, 2005 | 11:55 AM
BLk01SS's Avatar
Are they using C5R heads on the LS7?
Old May 1, 2005 | 09:32 PM
disassembled's Avatar
I am with jammer. Ls6 + 6.0 heads are similar and would be worth porting. I am going with 6.0 heads that are ported.
Greg
Old May 1, 2005 | 09:37 PM
69firebird's Avatar
Ronnie duke is using C5R head on his motor, but like jammer said, those heads have like 5cc combustion chambers, I was that post, that was a hell of a deal on the intake, heads , tb all that stuff, couldnt beat the price.
ed
Old May 1, 2005 | 11:29 PM
StoleIt's Avatar
NKAWTG...N
how much do 6.0L truck heads go for now adays? and how much would you pay for stage 2 6.0L heads? hope this doesn't hijack, figured its on the subject.
Old May 2, 2005 | 02:17 AM
I paid $500 for a pair of heads that had like 13k on them from an 03' truck. I have seen them a lot cheaper but i helped take the heads off so i had a bit of assurance being there from the time they came off till they got to my storage unit.
Greg
Old May 2, 2005 | 01:12 PM
No there not, the heads are modeled after them but not the same heads, the valve angle is different on the LS7.
Old May 2, 2005 | 01:14 PM
ed
There 13.5:1 CR so to make them work for TT I would have to change the setup, I think the ARF ported head will work perfect for me
