Damaged Exhaust wheel, What Cause This?
Old Apr 30, 2005 | 06:07 PM
kbracing96's Avatar
Default Damaged Exhaust wheel, What Cause This?
This is off my STS T60-1 turbo. I bought this kit used with about 1100 miles on the brand new turbo from Jason at TSP. He also sent me the tune. I've only put another 1500 miles on it since then. I pulled my turbo to change the housing to a .69 A/R exhaust housing to try to get a little more boost down low with the small 4.8 motor in my truck. But it turns out the .69A/r I got is apparently for an O trim and not a P trim wheel, so it wouldn't work. When I pulled the housing, I found this. I know the pic is a little fuzzy, but you can still see the damage. The turbo is still working ok and builds boost. I'm only running it at 7 lbs and according to my wide band I got the other day it is running really rich at WOT 9.8-1 AF, so it shouldn't have burned it off from running lean. Any ideas??
Old Apr 30, 2005 | 06:14 PM
Louis's Avatar
How do the plugs look? Typically its from an electrode on a plug more than not.
trtturbo's Avatar
Looks like something hit the turbine wheel. You will need to replace it and have it balanced.
Old Apr 30, 2005 | 06:20 PM
Arkangel77's Avatar
Well Mine looked similar to that and it was because I put some pieces of Pistion threw it. Looks like some type of metal hit it to me?
GOOOOOD LUCK!!!!!!!!!!!!!!!!!!!!!
Old Apr 30, 2005 | 06:32 PM
Avengeance's Avatar
Do you still have cats?
Old Apr 30, 2005 | 06:33 PM
kbracing96's Avatar
My plugs all look fine, they where new TR6's when I put the turbo on. Must have been that way when I got it, guess I'm have to give Jason a call.
Edit: yes I still have factory, unmodified cats. The truck only has 30,000 miles on it.
Old Apr 30, 2005 | 06:39 PM
Avengeance's Avatar
I have a funny feeling your cats are burning up and steadily sending tiny pieces into the turbo. This has actually been brought up as a STS concern a couple times.
With a ultra rich 9.8 A/F you may have caused the cats to go bad and break up.
Old Apr 30, 2005 | 06:41 PM
kbracing96's Avatar
On another note, what do you guys think about since I have to get a new wheel anyway, to go a head and get the O trim wheel and run the smaller wheel with the .69 A/R housing? Would it be too small for a stock 4.8? Right now I don't build full boost from a standing start till 4000 if I don't brake stall it.
Old Apr 30, 2005 | 06:44 PM
kbracing96's Avatar
I wouldn't think being to rich would do that to the cats, maybe if it was too lean and had excessive high exhaust temp, I could see that.
Old Apr 30, 2005 | 06:54 PM
Avengeance's Avatar
Cats are designed to reburn unused fuel thats coming out of the motor.. it "catches" unburnt fuel and tries to reburn it to keep emissions clean. When theres too much fuel coming out of the motor you can saturate the cat and cause it to go bad by overheating it, then it becomes brittle and start to break apart.
Old Apr 30, 2005 | 07:03 PM
kbracing96's Avatar
I guess that could happen over time, but I have only put 1500 miles on the turbo and It only runs rich under boost, not all the time. I haven't ran WOT that much since I got it, most of this miles have been highway miles.
I know Jason said he ran this thing pretty hard, 15+ psi on a 4.8 with a stock fuel system and a ton of meth. I've got a good fuel system, intercooler and am only running 7 psi and 18* of timing under boost.
Old Apr 30, 2005 | 08:09 PM
Armageddon's Avatar
...with cheese.
thats something I didn't like about my STS kit when I had it. I was always worrying about exhaust trash going through the turbo... It cost me a rebuild before I changed setups...
Old May 1, 2005 | 05:57 PM
kbracing96's Avatar
Anyone else got any ideas?
Old May 2, 2005 | 05:08 AM
MelloYellow's Avatar
Cats, remove them.
