Best long block assembly for over 10lbs of boost
I'm looking for opinions on what is the cheapest and best reliable bottom end and H/C combo for running a supercharger with 10-16lbs of boost. Let's here what you guys think. Also, i'm looking for aluminum since it's my z06 and I want to keep totally streetability and handling characteristics.
Thanks, Al
Ditto to what Jose said, and I would add ARP head studs.
If you can afford 205's you could keep them in mind.
I run:
~8.25:1 348 ci LS6 block
Diamond Pistons
Ported 6.0 heads
A1 head studs
236/246/114 Cam Motion cam
2.02/1.57 Manley SD valves, .100 longer than stock
1.7 Y/T rockers
Stock water pump
Comp 977 springs
Car made 754rwhp at 6600, in a stick that would be at like 6300 IMO.
and a set of AFR 225's , a 224/230 or 230/236 cam and of that's about it.
A Vortech T trim with aftercooler or front mount should do it.
ATI's D1SC should do it too.
There's a guy on the Vette Forum that road races that has a heads/cam supercharger combo his name is jbblownc5 or something like that.
Mike.
