MMS Pulley
Old May 6, 2005 | 03:00 PM
FormulaFire's Avatar
Default MMS Pulley
What gains do you get from installing a MMS pulley on a D1SC Procharger?
Thanks,
Justin
Old May 6, 2005 | 03:26 PM
LSs1Power's Avatar
A larger crank pulley will increase boost. 1" larger crank pulley equals .5" smaller SC pulley. It will also reduce the belt slippage because u can run a larger SC pulley and make the same boost.
Old May 6, 2005 | 04:03 PM
Blown SS's Avatar
Ditto, but they are kinda hard to find as MMS is out of business . I think it's worth hunting one down , I have one with no noticable belt slip .
Old May 6, 2005 | 06:54 PM
LSs1Power's Avatar
If u want an even larger crank pulley u can get the ATI 8 RIB crank pulley with the ATI Superdamper. Its 7.65" and u can upgrade up to 8.5" crank pulley. We are installing the 8.5" crank pulley as we speak and looking for 11-12psi.
