MTI R1 cam with a turbo??
If it were me, I'd go with something like a 224/220 on a 114. You should call around to places like COMP, Cam Motion, and Bullet Racing Cams to get their opinions.
I agree. I have a 222/228-115 sc cam in my engine. we made 560 on a mustang dyno @ 12psi and had to abort the pull at 6100 due to drivetrain problems. this was equal to 647 on our local dynojet. the curve was still climbing at more than 45 degrees. we would have made well over 700 at 7000 on a dynojet. and did I mention that this was with 4.10's on drag slicks??? we couldn't hold the car from spinning on the roller with the regular radials. I don't subscribe to the reverse split theory.
Thanks everyone
Tight LSA = more overlap
more overlap = greater high RPM VE
greater high RPM VE = more horsepower
The cam in my old turbo motor was ground on a 111 LSA and basically designed to make as much pump gas power as possible, if that tells you anything.
