STS & T-Rex cam
Old May 8, 2005 | 08:27 PM
Untouchable436LS1's Avatar
Default STS & T-Rex cam
i was thinking about this the other day, when thinking about the power that the STS kit comes in, and the power band of the T-Rex cam are about the same around 3-3500rpm your at full boost and with the T-Rex your in the powerband at about the same rpms. so i was wondering what you all thought about a combo like this, or do you think the T-Rex lobe separation would bleed off to much boost for a combonation like this to work. just throwing something out there. or maybe possibly having a T-Rex hybrid with similar duration and lift, but a higher lobe separation.
Old May 8, 2005 | 09:31 PM
LSONE's Avatar
that wouldnt work well at all.
good plan, but if you're going to get a custom cam ground, call up a sponsor and ask for their advice on the best cam for your application, also- with the huge engine your running, you could very easily run a bigger cam.
Old May 10, 2005 | 12:33 PM
OWENMUSTANG's Avatar
AGREE.
get a cam matched to this combo. will run WAY better!
