convince me...nitrous VS FI
date somewhere, mostly due to abuse and overuse. Im not completly against it if
it is done right and in proportion to your hardware (motor). But one of these days your going to push that button and KABOOM!
as for spray being dangeros, believe me, turbo/SC is just as bad.
and as for spray being cheeper. if it is, its not by much (to do it right that is) not an NX kit and a 150 shot. you start hitting it with 250 300 or more, and get a NOSzle system or derect port, man it aint cheep. stand alone fuel systems and regulators and safties and purges and so on and so on. its not as cheep as some would think.
you are in FL so I cant help you out down there, but i know if i was doing a turbo car W2W or Speed inc is where i would go (unless i did it myself working with ESP on a cusstom kit) or for spray, East Side performance is running some of the faster spray cars. right now we have 2 small motor cars going 9.6's and more on the way, and both my car and Gary's are going to go faster for sure. the season just started!!!!
either way, both setup have goods and bads. its what your wallet will let you do, and what you want from your car.
Eagle 408 ci :
-NEW GM 6.0l block
-Eagle 4.00" 4340 crank
-Eagle 6.125" H-beam rods
-Diamond pistons w\rings(flat or dish)
-Federal Mogul bearings
-ARP main studs
-balanced\blueprinted\assembled
for around 4000-4500
a 347 of the same caliber is going to run upwards of 3500 anyhow...so i figure what's the extra 500 bucks for a completly FRESH motor...i could get callies forged parts...but do you think i would need that much of an engine? it would be like a 1000 more
don't forget you are adding 90 lbs with a 408 cause its iron.
the supercharger is gonna give you torque, its not like a stock block can't make good power.
With a 408, to do it right, you'll need a good set of stage 3 heads and a bigger cam and you may have to get a bigger blower since you have to push more air in a bigger engine. Just trying to give you the total picture here.
Bottom line if you're a broke college student, keep your setup simple, go stock cubes, forged and spray it.
Yep. For the street aps, unless you are worried about making big numbers on pump gas without the meth / h2o injection, you really don't need to go to much bigger than stock cubes. If you want the added strenght and peice of mind, then go with an iron block, on a stock crank (which should last for a while), forged bottom end, a decent set of heads (ported LQ4s from a sponsor or AFRs or All Pros, if you can afford the latter) boost and go @ it. yes FI is hard on motors, but N2O is really hard on rings as well as bearings too. Instantanious hits of power vs. the somewhat softer gradual build of a S/C / turbo, will mean less tear downs and rebuilds (though if you are making power, expect to do that). Plus, if you were to go with the 6.0L right now, honed or bored .030 over, you wouldn't have to buy a new block when you go to a second rebuild (unless you junk it from a rod) you can clean up and go again, and put in the stroker crank the second time. Good luck, whatever you do.
Jeff
Forged 347, mild heads and cam, bf turbo, AND
Nitrous!
Then you'll have fine powerplant...
Or an elaborate bomb, I'm not sure
