banks twin turbo setup
Old May 16, 2005 | 12:19 AM
viper6913's Avatar
Question banks twin turbo setup
anyone have or know someone that has the banks twin turbo setup. i want to get it and to a ls1 in my 92 camaro but im just wondering if itll fit on the ls1
Old May 16, 2005 | 12:22 AM
CAT3's Avatar
Restricted User
The manifolds wont, and I doubt the rest would fit since it wasnt designed for such a compact area.
Old May 16, 2005 | 12:30 AM
viper6913's Avatar
then what kind of block should i use? just a reg 350 block nothing special
Old May 16, 2005 | 12:41 AM
Relativelyfast's Avatar
Dart block.
Old May 16, 2005 | 01:11 AM
2002yroneformula's Avatar
Yeah, it's designed to work with a carburated setup on a chevy small block. I don't know if it'd work on something like the Accel DFI or anything like that, but there's no way I could see it working on any newer GM motor.
Old May 16, 2005 | 01:35 AM
viper6913's Avatar
so i should just build a kick *** old skool set-up and it should/might work?
Old May 16, 2005 | 02:00 AM
CAT3's Avatar
Restricted User
Agree, Dart or Bowtie, with good guts up in it.
Old May 16, 2005 | 07:32 AM
sb427f-car's Avatar
SSU'S Vice Mod
Actually I believe that one of their setups is with an Accel DFI.
Old May 16, 2005 | 09:49 AM
viper6913's Avatar
if i built it from the block up does anyone kno where i can get some good motor mounts for that block or wil i have to make my own?
Old May 16, 2005 | 10:08 AM
Should be able to get it from anywhere that sells parts for SBC motor mounts in a third gen.
Old May 16, 2005 | 01:49 PM
viper6913's Avatar
what would be an ideal compression ratio and how should i go about get getting that ration. im thinking a 9.50:1 or 9.00:1
Old May 16, 2005 | 03:01 PM
Compression ratio sounds about right. I'd stay between 8.5:1 and 9:1 just cause i think 9.5:1 would be kinda getting a little high if you were wanting to run alot of boost. You can get the CR either by the pistons or the heads you run.
Old May 16, 2005 | 03:28 PM
RyanJ's Avatar
SSU Moderator
You should probably look at getting someone to build a good SBC for ya. There's plenty of experts that can help you. FastTimes, Duttweiler, etc., or even some of our sponsor's here.
Innovative Turbo bought a set of molds from Banks and will sell you a "tuner" kit (manifolds, turbo's, wastegates, and some other parts for less than the Banks kit.
Old May 16, 2005 | 05:20 PM
viper6913's Avatar
hmm...i could do that. and probably will. innovative turbo just sells the basics though. ill have to make all the piping and what not. would it be possible to sqeeze a intercooler in my 92 camaro?
Old May 17, 2005 | 09:34 PM
viper6913's Avatar
would it be possible for me to just get custom headers made for the ls1? and then i could just use the current setup that i have
Old May 17, 2005 | 11:11 PM
RyanJ's Avatar
SSU Moderator
Of course you can get custom headers made. But then there's absolutely no need for anything from Banks.
Old May 17, 2005 | 11:25 PM
Have you already got the turbo's? If not than it'd probably be cheaper to go with a kit that already has everything in it and will fit than having to custom make one, unless you've got the resources available to fab up your own kit.
Old May 17, 2005 | 11:41 PM
Wnts2Go10O's Avatar
old school 350 with a good bottom and a banls would be nice. the holley stealth ram makes good power with TT setups.
Old May 18, 2005 | 02:27 AM
GrnDragon's Avatar
So does anyone know if the banks manifolds definately will not fit under the hood of a 93+ Fbody? I'm wondering just about the hood closing, without modifications? Are the hood clearances of the older Fbodys that much more than the newer 93+? I know that the battery and ABS module would have to be moved/deleted. I'm still undecided on engine choice, but this would be one clean setup with a 427ci world aluminum block (which is made of a stronger material then a C5R block and costs 1/2 as much) and holley stealth ram or some other EFI intake.
Old May 18, 2005 | 05:04 AM
viper6913's Avatar
well according tothe guy i talked to at banks the kit will not fit, but that is for a third gen camaro. i figure it would be about the same for a 4th gen. the kit will fit on lt1 blocks. he told me i would need at least a 2 inch cowl hood. im not sure if it would be the same for your car but it might be. you could just go to the banks site and email them and ask them that question. but i think that im going to keep my current set-up and get some custom stuff made for the ls1.
