Another FI car running for the first time vid :)
I have no idea where the power is right now, probably around 500-525 through the unlocked 8" converter and 9 inch. I'll find out when I get the fuel fixed up.
Made several high rpm blasts and the belt stayed on fine and no slip, very happy with the SDCE setup so far. Put a couple hundred miles on it already, its a lot of fun to drive. Just have to put the roll bar in (finally got here) and figure out which seats I'm going to use.
http://69.128.2.214/k98ta.wmv
right click and save
I seen what kind of boost numbers you were seeing and I thought I would be seeing 8 or 9 here at 1500' elevation. I am winding it up a little higher then you (6500) and I have only a 01 Z06 cam so its probably close. Boost gauge could be off but if a new 255 walbro in-tank is running out at 5800rpm it must be making some ok power - I went through the whole fuel system today and everything looks fine, I'm putting one of those MSD boost-a-pumps on tomorrow and hopefully that will get me by until I do some fuel system upgrades down the road - then I'll try the 3.7 and 3.4 pulley
Hope you like the set up. I really liked it when my brother had it on his ride.
Take it ez, and good luck!
Eric
I just skipped all the BS this time, it turns out costng more doing things and redoing it over 10 times then to just tear the whole car apart and do it the way I want to start with. I have to run at least as fast as the cam only guys you know.Finished up the roll bar last night along with a few other little things. Going to go in a couple minutes and pick up one of those MSD volt boosters to get me enough fuel hopefully until I do the fuel system the right way - dont feel like dropping the tank right now after just putting it all together
Its a bolt in wolfe chrome moly 6pt, 62lbs total.
For real though, blower sucking up HP, TH400 sucking up HP, big heavy rear end sucking up HP...and you're fuel pump is DONE! Got to add all that up when figuring out injectors and pump...No Go made a good post about adding all this stuff in awhile back here in the FI section.I'd say you are making at least 530....
