Turbo running with out being complete???
Old May 17, 2005 | 10:48 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Question Turbo running with out being complete???
The question I have is does it hurt the turbo to be connected up to the hot completely, and not the cold side. Will this hurt anything? I have to get my truck back on the road and time is of the essences. Cold side I can get done while driving it day to day.
Ricky
Old May 17, 2005 | 10:49 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
No it won't hurt, but definitely not recommended. Nice setup by the way...
Old May 17, 2005 | 11:34 AM
MIGHTYMOUSE's Avatar
i would make sure an air filter is on the inlet so your blades dont get beat up durin the commute.
also make sure your oiling to and from the turbo is complete
Old May 17, 2005 | 12:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You are going to commute in the old Ducote car?
Old May 17, 2005 | 01:12 PM
speed~deelr's Avatar
You could definatly overspeed the turbo.
If I had the choice, I would recomend just blocking off the cold side from exhausting any air.
Make sense?
Leave the airfilter on the front of the turbo, and block off the exit of the turbo that would go towards the intercooler, or intake.
Merrick
Old May 17, 2005 | 01:24 PM
RyanJ's Avatar
SSU Moderator
Make sense?
Merrick
where would the air go?
Ricky,
What truck do you have with a turbo. Pics??
Old May 17, 2005 | 02:55 PM
Guido's Avatar
I wouldnt cover the compressor outlet either.
That would be like sticking a broom handle in the spokes of a bicycle.
Old May 17, 2005 | 05:18 PM
eviltwins's Avatar
Ricky,
It doesn't matter where the air would go. With little to no restriction on the turbo blades it doesn't take much exhaust gas to overspeed the turbo big time. I actually tore up a PT67 because I drove my car to work sans charge piping, it oversped the turbo, ruined the bearings, and the turbo had some vicious shaft play.
Old May 17, 2005 | 05:24 PM
NXRICKY's Avatar
No that one for now is just going to be weekend car. Nice call tho
Ricky
Old May 17, 2005 | 05:25 PM
NXRICKY's Avatar
Make sense?
Merrick
Could it over speed just cruising it.
Ricky
Old May 17, 2005 | 05:26 PM
NXRICKY's Avatar
Ricky,
At the point of no return. Build a turbo kit for my 2500 HD 02 truck. In the process of finishing the hot part tonight I hope. I will post up some pics as soon as I get some I like.
Ricky
Old May 17, 2005 | 05:27 PM
eviltwins's Avatar
Well, what car are we talking about? With a T'netics 105 it's doubtful that you could overspin it at sane street RPM levels, but why chance a 2500 dollar turbo to some cheap piping?
Old May 17, 2005 | 05:30 PM
NXRICKY's Avatar
I was asking for my truck turbo Chevy 2500HD 6.0L engine. The car will see very little street driving on the wet rainy days.
Ricky
Old May 18, 2005 | 01:03 AM
Brains's Avatar
Ricky drives like Miss Daisy, so it'll be ok
Old May 18, 2005 | 08:57 AM
NXRICKY's Avatar
haha
Ricky
Old May 18, 2005 | 09:07 AM
My84Z's Avatar
I say just throw a screen or filter on it so nothing gets in there or messes it up. get mesh from home depot if you have to.
Old May 18, 2005 | 09:25 AM
Ricky,
The air would go nowhere. What you are causing is a restriction, in turn slowing the turbine down. There would be some "barking" of the turbo, but some bark would be way better than severe overspeed.
I would atleast made a huge restriction in the exhaust side of the intake to slow the turbine down.
I have a '98.4 Dodge 2500 Diesel, and a '98.5 Dodge 3500 Diesel. Both twin turbo'd, both over 500RWHP.
Although I'm not too familiar with gas motors yet, I am extremely familiar with forced induction.
What did you end up doing?
Merrick
P.S. I'll get some pics later today.
Old May 18, 2005 | 10:02 AM
Here is my '98.4 12v.
It's turned up just a little bit.
I should have it on our dyno in 2-3 weeks.
Merrick
Attached Thumbnails Turbo running with out being complete???-my-12v-smokin.jpg   Turbo running with out being complete???-twins-top.jpg   Turbo running with out being complete???-twins-side-12v.jpg   Turbo running with out being complete???-12v-side2.jpg
Old May 18, 2005 | 10:04 AM
Here are the twins on my 24V.
Merrick
Attached Thumbnails Turbo running with out being complete???-twins-top-24v.jpg   Turbo running with out being complete???-twins-top2-24v.jpg   Turbo running with out being complete???-twins-side-24v.jpg
Old May 18, 2005 | 10:11 AM
RyanJ's Avatar
SSU Moderator
sweet...stacked turbo's. What kind of boost are you pushing? 60psi+? What else is done to the 12valve. I'd really like to do something similar.
