My 24 hour Pham single install.
in order to wire teh relay i would do it as such...hopefully other chime in but i believe that this will work out for you very well.
Find teh fuel pump power wire...it should be positive, connect this to pin 85.
connect a good ground to pin 86.
connect 87 to a good 12V power source of your choosing.
and then connect "30" to the power wire on the fuel pump.
"87A" should not be used.
When looking at the relay you should end up using the outside four pins and the pin in the middle should be blank.
NOTE: IF factory fuel pump turn on wire is a ground source PM me.
NOTE: if 87A is NOT the middle pin PM me.
That should work out for you very well though. what it is going to do is this...
when the factroy fuel pump turns on, the relay will connect "87" and "30" which in essence sends an excellent 12 volt signal directly to the pump.
Louie
Louie
TT-TECH Veteran
Yeah it is the grey wire in the back that comes off the electrical conections in the back by the rear end. And if you are trying to find it up by the fuse panel under the hood just look for the fuel pump relay and them if you turn the panel over you will look for the small red/Kinda pinkish wire that is the power supply. Hope this helps.
Jeff
Jeff
Restricted User
Did you cut an access panel in the trunk shelf or lower the tank to do the pump? If you cut the door, its easy, the connector at the top of the tank has the signal for the pump. If you want you can also go to the bulkhead behind the drvrs backseat...looking at the drvrs back seat backpad, it will be at the lower right area, goes through the wall to the front side of the rear axle tunnel. Look in front the axle you will see it bolted in, with a about 14 wires coming off it (not sure on exact number of wires) Sorry I cant be super specific, might try install university or ls1 howto?
Sorry I was MIA for the weekend. Finishing the pump tonight and then tomorrow is dyno day. They were not able to get me in this weekend so i gave teh install a rest as i dont wanna be done with it too long before i get to dyno it so that i dont go drivin around and break it without a tune. I didnt have to open above the tank or drop it cause i used a inline pump. Im finishing it tonight and hittin the rollers tomorrow at noon. Thanks
John
John
It is not the budget kit. It has the new manifolds that John made. It looks SWEET. Ill be taking more pics tonight of everything finished. Hope to get them all up tonight or tomorrow depending on when i get done.Thanks
John
John
Originally Posted by 99SS-T
Anyh chance someone knows where i can find the factory pump turn on wire? That might be tough for me to find with out any help... Thanks
John
John
#32
Im gonna be hookin the wire up to the bulkhead infront of the axle under the car. I hope that inspector12 is right about the wire back there lol. Ill make sure that we get pics up tonight or early tomorrow. Thanks.
John
John
#34
Trust me i am kinda confused as to why he aint put them up yet.....ill try again thanks
John
John
put turbo pics in it so it doesnt go to junk mail and ill host them and psot them..... i have LOTS od space
Kyle
oh yeah hurry up with the dyno info haha
