Spooling Faster?
Old May 21, 2005 | 02:26 PM
MY99TAWS6's Avatar
Less backpressure the better should help..try a cutout.
Also proven things..nitrous for sure.
You can put in a lighter flywheel like fidanza.
You can up your motor with a stroker. Bigger cubes the better and more compression does spool faster but then you can't run as much boost usually.
And BB do spin a bit faster and stay spooled between shifts better.
And of course the oldest trick is to simply downshift if possible.
Now not sure how much effect changing gears will have. Would think 3.73 would be about perfect but not 100% sure on that one. Thought someone said going to gears like 2.73 was actually better .
The tricks mentioned above the nitrous,flywheel and stroker or bigger cube thing is common with cars like my dsm. I am doing bascially that to allow me to run a big turbo yet have it hopefully all in by 3000 or so.
Old May 21, 2005 | 09:00 PM
Brains's Avatar
Was curious on the way home a little bit ago, so I decided to "test" something. Cruising ~60MPH ~2000RPM in 4th gear with the 'verter locked up. I edged onto the throttle to see if it'd spool. Sure 'nuff, it took a second but it started making boost at 2 grand
Old May 21, 2005 | 11:19 PM
KAOS's Avatar
i have a cut out, nice to here it spools so soon, which turbo is it
Old May 22, 2005 | 01:43 PM
Brains's Avatar
T76 Q-trim .96 A/R on-center ball bearing.
