difference between bypass and blowoff valve
Old May 21, 2005 | 08:53 PM
stryker14's Avatar
Default difference between bypass and blowoff valve
I think I understand the differences between a bypass and blowoff valve, but is there a difference in sound? I guess it was my understanding that a blowoff valve makes that recognizable turbo sound that we all know of. Now does a bypass have the same sound or would it be harder to hear?
Old May 22, 2005 | 03:19 PM
vhgjk123's Avatar
Hey man, I met you last night at Sonic, I was the one with the pewter turbo SS. Anyway, if I remember correctly a BOV and a bypass valve are the same thing.
Old May 22, 2005 | 03:43 PM
2000 Tran Zam's Avatar
from what i understand, BOV's are only for turbos as they open at X amount of pressure. the bypass valve is for superchargers because of the different pressure under load and at idle due to the pulley.
all i know is if you put a BOV on a supercharger, it will make an annoying chirping sound, or something to that effect. maybe someone else can pitch in and give a better explanation.
Old May 22, 2005 | 03:57 PM
whitt1's Avatar
My bypass valve has a vacuum operated throttle opening that bypasses the supercharger and allows for NA operation at part throttle and crusing operation,so there is no parasidic drag.
Old May 22, 2005 | 04:11 PM
conundrum07's Avatar
Same idea but the bypass dumps it back pre-turbo/blower and the BOV (typically) vents to the atmosphere. Like whitt said, the bypass is open under vacuum conditions and closes under boost. The bypass is going to be a lot quieter than a BOV.
