whats the diff between methanol and alcohol injection?
Old May 19, 2005 | 06:51 PM
seal's Avatar
Default whats the diff between methanol and alcohol injection?
what is it?
i heard methanol was specifically designed for automotive use til i looked into it, and it seems like it is an old invention lol
so whats the diff?
Old May 20, 2005 | 09:48 AM
BOONE's Avatar
Default alcohol
Originally Posted by seal
what is it?
so whats the diff?
Denatured alcohol, "avail at home depot and most places like it," is used mostly as a solvent, and does not cool the air charge as well. Straight meth is a higher octane, and cools way better, its more of a fuel, and i use it straight for just that reason, plus its a fuel so it cuts down on fueling needs a little bit. Denatured is less corrosive than meth so some opt for it, ive had zero problems with corrosion even from the rubber boot i spray it from, ive had it apart several times and its just like the day i put it on, even the plastic manifold. It vaporizes instantly under pressure, "its very volatile" Both are technically alcohol.
Old May 20, 2005 | 02:04 PM
WestSide's Avatar
Do some people inject windshield wiper fluid? Heard of that a few times...
Old May 20, 2005 | 04:22 PM
eviltwins's Avatar
Yeah but it doesn't work nearly as good as pure meth. Pure methanol is available for about 2 bucks a gallon in drum form.
Old May 20, 2005 | 04:38 PM
BottleRocket's Avatar
how does this compare to spraying the IC with CO2?
Old May 21, 2005 | 12:58 AM
eviltwins's Avatar
lol!
On a 70 degree night I see around 80 degrees for inlet temps with meth and 20 psi. CO2 does dick all for IAT's, you might see a 10-15 degree drop from normals and that's it.
Old May 21, 2005 | 12:59 AM
well that made up my mind
Old May 22, 2005 | 12:02 AM
HUGGER ORANGE SS's Avatar
Anyone out there running Meth injection without any intercoolers.. I'm thinking about going just stright blower to the TB with a meth injection..
I just wonder if the intercoolers are really helping that much with my power levels..
Clint
Old May 22, 2005 | 12:16 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
...And when folks spray meth, what is it the equivalent, 104, 110, C16?
Old May 22, 2005 | 01:54 AM
parish8's Avatar
single digit dreamer
i think that all depends on how much meth you are spraying. when i talk to may meth guy(julio), he likes to say there is no detonation point you can't supress with meth. if you get to a level where it is detonating just give it more meth and it will go away.
while i dont doubt this there has to be a point when you are flowing so much meth there is a distribution problem if you are not spraying some in each port.
what this is telling me is i need 8 nozzles, one for each runner and i should be able to run as much boost as i want. the pump that came with the kit is huge and runs at as much as 200+psi. i have a 4 gallon cell so i shouldn't run out.
Old May 22, 2005 | 01:56 AM
CAT3's Avatar
Restricted User
My buddy sprays meth on his Dakota with Novi 2000 no IC, his temps are slightly above ambient, not exactly sure how much more. He uses straight Meth, not mixed with water.
Old May 22, 2005 | 07:05 PM
seal's Avatar
the more water mixture in the meth, the cooler the intake tempatures will be
Old May 22, 2005 | 08:31 PM
9secpacecar's Avatar
i heard washer fluid is the same is this true? thanks and what kinds!
Old May 22, 2005 | 08:36 PM
parish8's Avatar
maybe, but the less you can spray before you bog the motor.
i think people use washer fluid but only in a pinch. the ratio of meth to water is not known for sure and may vary from bottle to bottle or from brand to brand. if your set up can handle strait meth i would just stick with that.
Old May 22, 2005 | 08:50 PM
Washer Fulid is only about 30% Meth... You could use it, people do.. I would rather go stright Meth or 80/20 Meth Water..
Clint
Old May 22, 2005 | 10:20 PM
seal's Avatar
i go with 25 meth 75 water
i'm really happy with the way car is pulling... as a matter of fact, its actually making me run rich even with 25% meth... might even do 20 meth 80 water...
Old May 22, 2005 | 10:41 PM
Lostpatrolman's Avatar
parish, what do you believe the limit is that requires a nozzle per intake runner? What kind of boost levels are we talking about?
Old May 22, 2005 | 11:38 PM
parish8's Avatar
i have no idea. julio says when you are replacing 20-30% of your fuel then you are probably near the limit but he has guys spraying with one nozzle per runner to get past that number.
20% fuel replacement is a lot of fuel for my truck, i have a long ways to go. the only thing i can think of as a comparison is a wet shot. i would not be afraid to spray a 200 wet shot so a person could calculate that amount of fuel and asume that you could flow at least that much meth and still get decent distrabution.
another thing for me to consider is there are guys with 3.8L motors spraying way more meth than i am right now. i should be able to look at what they are geting away with and spray even more.
Old May 22, 2005 | 11:45 PM
seal's Avatar
jeesh now thati'm reading my posts, i got it the other way around
i'm running 25 water, 75 meth... not 75 water 25 meth lol
actually, i dont really know what i'm running haha... i borrowed some from my friend, and it was 25/75 something lol
Old May 23, 2005 | 12:12 AM
trtturbo's Avatar
So if someone drilled the intake and installed one injector in each runner and used an injector that was small it would work? Is this worth it over just doing one injector before the throttle body? It seems like it would be more efficient at getting all the cylinders cooler.
