looking into sts setup
Old May 20, 2005 | 11:41 PM
nyg215's Avatar
Question looking into sts setup
hey im new to this part of the forum. i want to get the sts system but i dont know that much about FI what else will i ahve to do to my motor so i can run alot of psi? and will the cam i have in right now work ok with FI? the cam specs r in my sig. need info?????? thanx
Old May 21, 2005 | 08:20 AM
Wolfee's Avatar
Do a search on STS. Most peeps won't even bother with someone asking questions about these things anymore since they have been talked about SO MUCH. If you do the search ALL your questions will be answered, guranteed!
Wolfee
Old May 21, 2005 | 08:33 AM
trtturbo's Avatar
Forged pistons, good rods, ARP head and rod bolts, bigger injectors, pump, intercooler, 226 on 116 or so cam, and a good tune. Hope this helps. You said you wanted to run alot of psi!
GhostZ's Avatar
Your best bet is to do a search. Probably every question that could ever be thought up has been asked and answered in either this forum or the FI section at CZ28.
Search and spend the hours reading and if you have other questions that weren't answered in your searches....ask them and I'm sure you'll get responses. It's nothing personal but your questions have been gone over sooooooooo many times that most folks don't want to regurgitate that information one more time when it could be had easily by you if you'd only use the search feature.
Old May 21, 2005 | 09:02 AM
ddnspider's Avatar
what he said...minus the need more a 226 duration.....it doesnt need to be that big....a stock cam will even work well...but the LSA is important...most say at least a 114
Old May 21, 2005 | 09:39 AM
trtturbo's Avatar
I just figured he would want to keep some cam since he already had it.
Old May 21, 2005 | 10:09 AM
eviltwins's Avatar
A 112 LSA will be fine. Tighter LSA promotes better top end breathing for more power.
Old May 21, 2005 | 02:13 PM
ddnspider's Avatar
if hes planning on a forged SB and a well flowing exhaust then yes he can run a tighter lsa
