FINAL DYNO #'s W2W 408
The car was "breaking" up around 5K....after a month of chasing, the gremlin ended up being a Crank Position Sensor. Anyway I'm glad it's fixed as you will see below.
Made several pulls (No dyno tricks) and the car ran like a champ with no problems at all
Here's the results....D1SC Procharger @ 14PSI
626 RWHP / 625 RWTQ
http://www.cardomain.com/member_page...21_11_full.jpg
D1SC Procharger @ 14PSI + Nitrous (Dry Shot before the I/C's)
704 RWHP / 702 RWTQ
http://www.cardomain.com/member_page...21_12_full.jpg
I'm very happy considering this was in full street/show trim (minus AC...I have T-Tops
). I'm still using the ATI Twin I/Cs, the cam is relatively small for this motor 228/230-581/592, and I still have my 5.7 heads with slightly larger valves.Thanks again to Kurt, Billy and the rest of the W2W team for a great shortblock.
Add one more badass F-body to the Ohio list
...the rest of the states need to get on it!Mark
Was the crank position sensor messed up, or the wiring? Sometimes the wiring get burned because it runs down by the #4 and #6 header primaries.
Yep... all it takes is time and plenty of $$$ Thanks god i have a new sponsor.........
I just hope when i let him drive he doesnt go faster then me in my own car
Kyle
It was only the switch, wires were fine.
While we are on that subject....anyone know if flywheel torque has the same loss?
Kurt, if I "drive it like I stole it"
I'll be back in the garage working on the drivetrain, 10 bolt specifically
.I beefed it up as far as I can: Moser Axles, Auburn Racing Carrier, TA Aluminum Cover with Bearing Preloads, and a GM Superior 3.42......I just don't think it would hold up to much of a "launch".
It's going to the track though....I'll leave at idle and see what the ole "show" car will do. That's why 2001WS6VERT and I are partners on a race car. To satisfy our urges and build it to beat on it from the ground up!
Mark
that things got low 10s written all over it. maybe 9s i hope for ya w/ the 12-bolt and stickys
what you wanting to run?
. I just want to run her once or twice...as Reckless said..it's really a show car.
Darn, I thought it was the cam sensor. Wrong sensor I guess
