Horsepower Estimate
Old May 22, 2005 | 09:43 PM
BlownBird68's Avatar
Default Horsepower Estimate
* Any guesses to what kind of horsepower/torque I can expect??
* What about track times? . The car weighs about 3400lbs, TH350, 9inch 4200stall converter, 4:10 gears 28x10.5 Et street tire & 12 bolt rear.
Engine - GM "010" 357Ci . Arp studded-Aftermarket Main Caps
Bottom End- "Eagle" rotating assembly
Heads- 200cc Canfield Aluminum Ported & Polished
Camshaft- Howards custom roller cam 112 center lobe, 240-250 duration, 580-600 lift.
Compression- 7.9.1 using cometic head gaskets
Carberator- "TheCarbShop" custom 950cfm Blown Thru
Fuel System- Aeromotive A1000 fuel pump and Aeromotive bypass regulator, 1/2 fuel line, 3/8 return.
Blower- ATI F1 @ 15lbs of Boost
Ignition- Msd btm
Intercooler - None
Old May 23, 2005 | 07:35 PM
2000 Tran Zam's Avatar
that compression seems quite low. is this gonna be a track only car? or street/strip combo? due to the size of the stall, the 12 bolt, TH350, and low compression, i would have to guess a max of 550 or so RWHP. however i could be wrong. are you wanting to max out the boost with your setup, or whats the reasoning for the less then 8.0 compression?
Old May 23, 2005 | 11:31 PM
GM block saftey
