Catch can setups on Prochargers
Old May 25, 2005 | 09:02 PM
matrepk's Avatar
Default Catch can setups on Prochargers
I have the standard setup that Ati suggests that you use according to the manual with hooking the hose from the blower intake to the pcv on the passenger side. What is the best way to hook a catch can set up into this system? Whats lines need to be hooked up to the can and where from?
thanks
Old May 25, 2005 | 09:19 PM
Blown Ta's Avatar
i put a greddy catch can between the pcv hose and intake manifold, and installed a checkvalve. and a cheap oil separator between the pass. side valve cover and blower inlet hat. works good, i got no oil in the intake or the inlethat yet.
Old May 26, 2005 | 09:11 AM
BOONE's Avatar
Default catch can
I went valve cover to catch can, then to replacable paper filter "clear plastic so to see if oily," then to inlet hat, and i have put thousands of miles on the car and have seen no oil in the catch can at all, just discoloration on the tubing. And im hard on it. No pcv at all.
Old May 26, 2005 | 11:55 AM
snkchrmr's Avatar
Here's a pic of mine.
http://photobucket.com/albums/y142/s...undrhdws62.jpg
You can see the Greddy catch can infront of the passenger valve cover.
Old May 26, 2005 | 04:44 PM
matrepk's Avatar
thanks for the help, that gives me a good idea of where to start with this.
Old May 26, 2005 | 05:19 PM
~JOSHUA's Avatar
I have a Greddy catch can in 98% condition I'd sell for $60 shipped if anyone's interested.
