how to lower compression on 6.0l
Old May 27, 2005 | 05:50 PM
Sn8ke_Eater's Avatar
Default how to lower compression on 6.0l
how do i lower compression without changing pistons i was thinking head gaskets? i will have sts gt70 with milled ported heads, cam,60# injectors fmic so i want to try to max the turbo but do not want to do it on 10.1 compression.
Old May 27, 2005 | 05:52 PM
RyanJ's Avatar
SSU Moderator
swap heads. Using thicker gaskets increases your quench area and can lead to increased detonation.
