LQ9 w/mods and SC?
Old May 28, 2005 | 12:09 AM
TrueBlueGTO's Avatar
Question LQ9 w/mods and SC?
Gentleman,
Does anyone forsee a disaster waiting to happen with taking a stock LQ9 6.0L HO engine, adding an LS6 intake, (200/203, .500/.500) cam, 1.8 roller rockers, and 7 psi of Vortech boost? What kind of crank HP numbers should I expect? What's the max safe RPM on the stock bottom end (it will be backed by a 6 speed)? Is a return fuel line critical?
I'm also thinking of maybe keeping the cam (196/201 .467/.479)stock and add the other mods to keep good bottom end and midrange for the road. I figure the SC will be enough to keep high rpm runs with enough air. Thoughts and opinions?
Thanks in advance.
J3
Old May 28, 2005 | 12:14 AM
Based on what I have read on the LS2, it seems like I'm building a lower compression (10:1 vs. 10.9:1) LS2 with a sturdier block.
Old May 28, 2005 | 01:07 AM
narcszm's Avatar
that's not even close to disastrous. a stock bottom end with a mild cam and 7psi of (even non-intercooled) boost should last and last. Just don't spin it over 6300 and you should be fine. those rod bolts are the limiting factor.
Old May 28, 2005 | 03:08 AM
thanks Narcszm....my gut felt right, but I wanted to confirm. Personally, I prefer to build a motor that is reliable and works easier to make better use of the power it has rather than harder to achieve higher numbers. So my plan will include details such as upgrading the rod bolts, adding the timing chain dampner, modding the oil pump, upgrading the springs/retainers, and adding a keyed fluid dampner. Maybe later in the year I'll do a full CNC on the heads and add headers. Any idea how much power she should be good for? I'm speculating 550 or so at the flywheel.
A good, trusted friend suggested I build a power engine combo that relies more on motor than boost. I 'll be less likely to beat it as badly and should be rewarded with better fuel economy b/c I'll not have to put my foot into it as much for the thrill. As a member of 3 generations of family truckers, in TORUE I trust. Therefore I look at the SC's role more as an aspirator assistant....I don't want to go boost crazy. Worst case scenario I'll add a 50 shot and Evans Cooling water pump just to cool the engine and charge temps...but that will be way down the road.
My curiosity is tingling at knowing the limits of this stock motor. I mean if backyard mechanics have been able to build deadly Gen I small block motors out of junkyard parts, surely the state of the art (comparatively speaking) LQ9 can make some wicked power.
Old May 28, 2005 | 04:18 PM
ddnspider's Avatar
no problems at all,that cam is really small and youre not even pushing alot of boost.
