Harlan Stutter box
Old May 28, 2005 | 07:36 PM
TchargedLS1TA's Avatar
Default Harlan Stutter box
Wondering if anyone has the install instructions for this..
Old May 28, 2005 | 09:21 PM
NYSS Guy's Avatar
see the post you have on the other site. I hope that helps.
Old May 29, 2005 | 11:17 AM
How will that activate the box? I mean obviously the switch to turn it on, but how will it disengage when I leave the line?
Old May 29, 2005 | 04:28 PM
NYSS Guy's Avatar
the connection at the pcm is the cruise control disengage switch. So, when the clutch is fully engaged, it will shut off the 2 step.
Old May 29, 2005 | 05:12 PM
What about for an automatic?
Old May 29, 2005 | 07:00 PM
NYSS Guy's Avatar
Hmmm, let me find the destructions again, and see what it says.
Old May 29, 2005 | 07:28 PM
NYSS Guy's Avatar
Okay here are the instructions word for word:
White wire (Arming Switch): Momentary switch to ground.
Normally open, close switch to active
Gray wire (Hold Switch): Clutch pedal switch, foot brake switch, or custom.
Normally closed to ground, open switch to active.
Again, on a 6 speed, it pulls the signal from the cruise control deactivation switch, so you may have to figure out something similar for the brake pedal.
Old May 29, 2005 | 07:29 PM
NYSS Guy's Avatar
I just thought of another idea...I wonder if you could wire both wires to a regular switch, but then you'd have to switch it off as soon as you launch. Not sure if that would work, but Im just thinking out loud.
Old May 29, 2005 | 09:54 PM
DERTY's Avatar
The Bull
If you wire the white and gray into a single momentary type button you can use the two step like a transbrake button. Also, with an automatic you can wire the two step into the transbrake by using a relay.
