Alternator and TTi kit speed rails help!!!
any one have any suggestions
need help fast!!
what you need is some npt to hose adapter
also youll have to trim the cover on our alt
try checking out some pictures here
http://www.cofba.org/users/smokinhawk/fuel.htm
mine looks exactly like this
http://community.webshots.com/photo/...64993768hYNLOz
so that 90 i have is not what i need??
do you have a picture or a part number for
i cant find it on summit site by doing a search...
Russel 90° 3/8" pipe to 1/2" (8an) hose connector
this is sinister garage computer
just speed inc----anyaftermarket high flow rails....
stock i had no problem....but meh who likes stock hahha
i think i got it figured out im gonna hog the 4 bolts abour a 1/4 inch in and should give me just enough clearence..
once again this is sinister
John
i had to switch to these when i ran my alt. that way.
correction for mine i had to run
rus 612-100..
the 110 are 1/2 npt male thread..
my speed rails required me to run 3/8 male npt threads
i will delete both after i figure out how to do this
help!
On ZAngel's car, we ran the X-over in the back, and simply put the pipe plug behind the alternator. the fuel feed comes in the front of the driver's side rail with a 180 degree hose end, a short section of line, then a 90 degree hose end. Then we have a quick-connect adapter connecting to the factory soft line..
soon as i got that new fitting it worked perfect it was a lil tight i had to trim some of the plastic away from the back of the altinator.
any chance of getting one of those brackets you fabed up for z angle or a cardboard template? i like that alot better then the one from tti
How is the MS intall doing, and how is it working? Also is that PVC pipe comming out of the intake
Thanks
ed
firebird455@gmail.com
I don't have any templates on the alternator bracket, I kinda cobbled it together in the garage in an hour or two 69firebird - MS has been running the car since it first fired up with the turbo, and has been doing great! We have basically been tuning it on the Power Tour - in fact, with me at the wheel and Tiff tuning, we pretty much have all the tuning in boost done that we can do on pump gas.
oange ss - The adapter is a custom piece from Nitrous Express. Try PM'ing NXRICKY on the site here, he can get you pointed in the right direction - its his design
. but i guess you guys are good at drive by tuning, i would be scared shietless to try tuning my car via guess and check. also
me orange ss discoverd if you take the black plastic of of a s-10 altinator and put it on the one for your ls1..it fits perfect no cutting needed!
ornage ss took pics of it he will post dem up
http://brian.grimal.com/gallery/view...umName=album21
